TR2/3/3A new rings
TFB
I am intsalling the no name rings that came with my Moss 86mm liner/piston set.
My question is about the 3 piece oil ring which has a about a 2" long wire threaded through the expander/spacer ring,bridging the gap.
It seems like nothing keeps it from moving.It looks like its designed to keep the ends of the spacer aligned.
Is anybody familiar with this oil ring design?
BTW the Moss kit nothing is branded but the pistons have "county" cast on the inside.
Thanks
Tom
mctriumph
Never seen this, I suspect it is a "dummy " to be removed when the first scrapper ring is set in place to hold the expander alignment.
The second scrapper finishes the job.
Do Not underestimate, this must be done right......or its Wrong
Mad dog
T
TFB
Thanks MD,Actually searching the web for info on oil rail gaps(mine seem very big),Grantrings.com site under ring styles showed ring *wl wire latch" that show this style ring.I assume they stay in,you cant remove once you put in a scraper.
Still not sure about the big oil ring rail gaps.
Tom
CJD
+1...I've never seen anything like that. If you have time, I'd appreciate a pic.
T
TFB
Hey John,not sure how to post pic but if you go to grantpistonrings.com,then piston rings,drop down piston ring styles.
I think this style is patented by grant and the wire has a little 90 bend ,not shown on chart,on the ends so the wire is not removable.
I think the rings I have are maybe a design knock off with wire having no end bends ,so you could expand the expander and remove the wire,which prompted my original question.
Once the style I have is installed with the rails the wire can move but cant come out.
One of things I never liked with three piece rings is the possibility of the expander ends not being properly aligned.This design seems to eliminate that problem.
Thanks
Tom
CJD
Yep. It looks like an attempt to prevent overlapping the wavy ring. I have rebuilt several dozen engines over the years, all using 3 piece oil rings and never had a problem with the wavy ring. Based on past posts, I guess a lot of builders do. The key is to take a good look at all the rings after installation, and while you are orienting the gaps, and an overlapped wavy ring is quite obvious.
If that little wire CAN come out, I would make sure to remove it. Any metal sloshing around an engine is not good.
bobhustead
I looked at Grant's site and saw the WL style. I don't like and would not use the WL rings with the wire in place. There is an old saying : 'just because an engineer can do something doesn't mean you should let him'.
Bob
T
TFB
Thanks for replies.
The wire can only be removed by expanding the wavy ring to about 1 1/2 ".Once its on the piston and the scrapers are in the wavy ring cant expand and wire is captured.The wire can move side to side a couple of wavy ring segments,but not past the gap.
I left them in.
Better instructions included would have been nice.
Tom
KVH
Overlap is a huge issue for me. It's happened despite what I'd say was great care. When you tap the piston down, you simply can't see what's happening to the wavy ring, the oil scraper ring. For me, I'd be happy to use a ring with a safety wire like that. My other advice is to be absolutely certain you were sent the correct rings. I my case, they were wrong, and only a production note at Moss (in their internal sales manual) saved me.
T
TFB
Thanks for reply kvh,My rings were marked on the comp rings"xr8600".and fit @.015 gaps.
The scraper rings for the oil ring had larger gaps,around .040.
Can you elaborate on the problems with the rings and the production note in moss internal sales manual.
Thanks
Tom
KVH
Probably irrelevant to 86mm. The issue was 87mm where two nomenclatures were used: 87mm and 86 oversized .04 inches. They were actually different.
T TR2/3/3A rings inside bevel Triumph 2
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
D TR2/3/3A TR3 Headlamp Rings Triumph 8
P For Sale Wheel trim rings Triumph Classifieds 5
R Wanted Whish list: Wheel trim rings and... Triumph Classifieds 9
M TR2/3/3A How many miles to seat piston rings? Triumph 4
cpbol Oil Rings Austin Healey 1
P For Sale O-rings for Smith and Jaeger gauges. Other British Classifieds 2
K TR2/3/3A The chrome rings that go on the face of the guages? Triumph 1
S TR2/3/3A rubber O rings that go around the gauges Triumph 5
HighAltitudeTR3 TR2/3/3A Just rings?! Triumph 17
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
D gapless rings arrived today Austin Healey 1
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
mgedit TR2/3/3A O-Rings for TR3 Gauges Triumph 9
jfarris TR2/3/3A Oversize Rings 83mm Triumph 7
KVH General Tech Installing the Pistons and Rings Triumph 7
K TR2/3/3A Pisto rings again... Triumph 4
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
HealeyDave General Tech Bending tabs on chrome gauge rings Triumph 5
B Kin Pin Kit - O-rings Austin Healey 1
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
Jake OD unit operating piston rings? Austin Healey 1
S TR2/3/3A pistons have 4 rings Triumph 28
oxford piston rings Austin Healey 4
oxford Syncro rings Austin Healey 7
L Instrument O rings and switch plate mounting Austin Healey 4
P Guages with gold rings Spridgets 2
Tim Tucker TR2/3/3A TR2-4 86mm standard rings Triumph 10
RAC68 Seating Rings with Rust? Austin Healey 24
dklawson GT6 GT6 Con Rod Bolts & Grant Piston Rings? Triumph 5
R TR2/3/3A How do I install the headlight rings on a TR3 ??? Triumph 8
O TR2/3/3A TR3 Headlite Trim Rings and Front Parking Lite? Triumph 10
B Spitfire big bearing snap rings on Spit single rail Triumph 0
5 Piston rings 100/6 Austin Healey 3
M MGB Help! MGB Baulk rings MG 2
6 piston rings Triumph 15
H Sanding the paint, like rings on a tree Austin Healey 8
6 rings,valves&guides Triumph 8
6 rings? Triumph 5
MGTF1250Dave Piston Rings Triumph 4
hymodyne MK III pistons and rings Triumph 3
M MGB Source for "good" MGB syncro rings? MG 4
mountainman TR2/3/3A TR3 Beauty Rings Triumph 4
Tr4dude TR6 tr6 center caps and trim rings Triumph 3
T Tips for locating/fixing foam rings under gas tank Triumph 4
M MGB MGB syncro rings MG 0
Stinger TR4/4A TR4A Headlight Trim Rings Triumph 4
