Piston rings 100/6
5
57_BN4
Today I was cleaning the carbon off my pistons ready to reinstall them back with the old rings as the engine hasn't even run enough to bed them in, when one of the lower oil rings fell off the piston. It is broken in half and must have happened upon the original install as the broken ends are polished where they have been moving around. Engine is sleeved to standard with new pistons/rings 2000 miles ago before being parked up for 13 years.
1)Are there any recommended brands of rings to get? I'd prefer the multi-piece oil rings rather than the present single type.
2)What about rings from other applications? 1963 Jeep I4 has same dimensions and more modern materials
https://www.summitracing.com/parts/SLP-E-104KC/
3)What is the general philosophy about removing/leaving the fifth ring below the gudgeon? Original pistons didn't have them and I haven't really understood why the replacement ones did.
Cheers,
Andy.
Call up Total Seal piston rings (Flagstaf, AZ?) and give them the dimensions of your oil ring and they can supply just a set of low-tension oil control rings, if you like.
But, while you're at it, I strongly recommend that you ask them to supply you with a set of "Gapless" 2nd rings.
Based on their prices, you may elect to replace the entire set, they're not expensive, by comparison.
57_BN4
Hi Randy,
Thanks for the info. I tried their website and our local agent here, they both say TS don't do a 3 1/8" ring at all. Do you have a part number?
Cheers,
Andy.
Superwrench
Andy, They show a 3.130 ring. That will work. Like Randy says, call or email them and talk to Kevin Stoddaker. He will hook you up with everything you need. Good luck !
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
M TR2/3/3A How many miles to seat piston rings? Triumph 4
2billydavies TR2/3/3A need an educational lesson about piston rings Triumph 14
Jake OD unit operating piston rings? Austin Healey 1
oxford piston rings Austin Healey 4
dklawson GT6 GT6 Con Rod Bolts & Grant Piston Rings? Triumph 5
6 piston rings Triumph 15
MGTF1250Dave Piston Rings Triumph 4
Don_Racine Triumph Piston Rings from Deves Triumph 1
Don_Racine Free Set of Deves Piston Rings Austin Healey 0
TR674 TR6 TR6 Piston rings Triumph 10
P 60's A55-A60 STD Piston Rings Other British Cars 5
5 948 piston rings Spridgets 5
David_K BJ8 Piston Rings Austin Healey 4
Mark_Gibson Piston Rings 101 Triumph 10
Banjo MGA MGA piston rings MG 3
K TR2/3/3A Piston slap? Triumph 3
T TR2/3/3A valve guides and piston clearance Triumph 6
Simmo TR2/3/3A Something is eating away at my Piston Liners Triumph 15
D Separating the piston from the connecting rod. Spridgets 9
J Piston Coating Austin Healey 3
KVH General Tech Removing Piston Wrist Pin Triumph 2
sail TR4/4A Piston Ring Question Triumph 6
M Wanted WANTED...New TR6 piston set. Triumph Classifieds 2
K TR2/3/3A Brake caliper piston install? Triumph 18
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jayplum TR2/3/3A TR3 Piston Sleeves Triumph 36
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
BJ8Healeys Disc brake piston seals Spridgets 2
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
M TR2/3/3A Please Help ID This Piston Triumph 6
Got_All_4 TR6 Are these piston nitrated coaded Triumph 5
J TR2/3/3A 83 to 87mm Piston Considerations Triumph 7
Gerard 1275 piston ID Spridgets 2
HighAltitudeTR3 TR2/3/3A Piston Slap đź‘‹ Triumph 12
M TR2/3/3A Sleeve and Piston Sizes Triumph 6
Got_All_4 TR6 Depth of the metering needle in the air valve piston Triumph 12
steveg Piston options for Healey Austin Healey 12
T TR2/3/3A SU Piston Drop Test Triumph 4
C TR2/3/3A Piston gap orientation Triumph 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
T General Tech Brake caliper - piston stuck Triumph 4
KVH TR4/4A Piston Size Measurement on Rebuild Triumph 4
JPSmit Brake piston removal - McGyvered some tools Restoration & Tools 0
W TR2/3/3A Piston and Liner Triumph 2
tinman58 TR6 Piston clearance Triumph 4
