mounting of rear seat pans for BJ7
chicken
My second hand seat pans each had 4 no. flat headed studs welded in that i believe secured them to the car, these in turn i guess were covered up by the seat covers.
However in looking in some books pictures show what look like 4 screws going through the seat cover & pan and securing them that way.
My question is which is the correct way to do it.
Also on another post there was some talk of securing them with velcro for easy access to the fuel pump, any comments.
One last quiery, do the front seat runners bolt directly to the floor and then the carpet cut round them or is the carpet laid first.
Rob
stevebn2bj7
The rear seat pans in the BJ7 had the same mounting procedure as the BN4 and BT7 where they were attached with four screws. Probably a philips oval head with a finishing washer. The pans you have are from a BJ8 where they were undermounted. In my BJ7 I mounted the pans like a BJ8 because I did not like the look of the screw heads.
THe front seat runners bolt directly to the floor after the felt paper and before the carpet & pad.
chicken
chicken
Steve
Having read the book i take it that tar paper is just the same as roofing felt, do you know of what grade & does this cover all the floorpan area.
Rob
vette
My seat runners had a strip of wood about 3/16th inch thick between them and the floor. Might have been oak.
bob hughes
Careful with the wood Vette, do you think it grows on trees !
I think that the wood compensates for the carpet thickness allowing the seats to slide over the carpets.
Bob
Cutlass
I'm in the process of refurbishing my BJ8 rear seat pans, and of course all studs need replacing. These started live as 10-32 x 3/4 inch machine screws, with flat, round heads spot welded to the pan in four places. My solution was to knock out the old, broken stud, fabricate and weld in new studs. Not wanting to even attempt the quest for new studs, I drilled a 3/16 inch hole in some 1/4 inch steel flat bar, and inserted a 10-32 x 1" phillips machine screw. A few seconds of working with a ball peen hammer on the head produced a very nice flat head, about the same diameter as the old stud. This weld in very nicely, and will be invisible anyway.
Cutlass
Sorry for my grammer. The boss might come in any minute and find me goofing off. This might result in dinner out tonight.
chicken
chicken
Cutlass
I guess that was the conclusion i am coming to as they wont be seen anyway, what do you mean by 10-32 is this the size (i'm a metric man).
Should the rear seat pans fit snuggly/tight in the rear holes or is there tolerance left for the carpet etc, my untrimmed pans seem to sit a bit proud of the hole at first sight, does the hole need trimming back do you think ?
Rob
Cutlass
Rob: 10-32 means a number ten machine screw, thirty-two threads per inch. It's about 3/16 inch in diameter. As far as fitting is concerned, I'm not there yet. I disassembled the car four years ago, and am just now in the final paint stages. So your question about fit is beyond me for now. Others should know. Jim
Don't trim the whole any larger, the offset allows the carpet to go under the seat pan.
chicken
chicken
Longbridge Healey
Do you have anything else under the rear seats, like jute/foam used in the front of the car.
Rob
All there is under my rear seats is the carpet and a layer of insulation (dynomat) which certainly isn't original. Of course this doesn't extend under the seats, just around the rim of them.
Cutlass
Seems like an application of something like 3-M's Rocker Panel chip resistant coating would be a good idea for the underside of the rear seat pans. They are pretty well just hanging out there to the elements.
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
R Mounting rear shroud rain gutter Austin Healey 14
K TR2/3/3A Rear tonneau capping plates and bridge pieces for mounting the Hardtop? Triumph 3
mt10flyer TR2/3/3A Rear shock mounting plate Triumph 28
B rear wing mounting on my 57 Triumph 5
vette Next Question on Rear Springs Mounting Austin Healey 2
J Question on rear brake mounting plates Spridgets 5
N MGB-GT 1971 MGB Rear Shock mounting bolt length MG 0
memphis License Plate [rear] Mounting Location? Austin Healey 12
mountainman TR2/3/3A TR3 Rear Fender Mounting? Triumph 4
tahoe healey rear license late mounting. Austin Healey 11
H IRS diff rear mounting bracket Triumph 0
C Mounting hole location for rear chrome bumper Spridgets 2
Lin Rear Wing mounting Austin Healey 0
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
