Mounting BJ8 Chassis on Rotisserie
Martec
Hi
I am about to mount my BJ8 chassis on a rotisserie. I was planning on using the front and rear bumper mounts as mounting points. Does anyone with experience doing this see any issues using these mounting points?
Thanks
Deleted member 26968
Hi, No that will be fine. That's how mine was done and no issues at all.
Regards
Barry
Hi Thanks for the photo's. How did u find the center of gravity so it would rotate easily?
Hi, It is happier with the bodyshell hanging down, naturally. If you want the car on its side you may need a locking device to prevent it from rotating back to its happy space. Without seeing what you have I can't advise you.
Cheers
Barry
robolab
this is my construction. By moving the flange plate (the plate with the 4 screws) I was able to adjust the pivot point so that I could turn the body with one hand.
red57
Gerd, I think your method is better than mine - I drilled a series of holes on about 1" centers in both the front and rear mounting arms so lack the 'infinitely adjustable' nature of yours. I did also get to where it was easy to rotate by hand.
BTW, I found with the totally stripped chassis, that the center was near where the center of the crankshaft would be if the motor was installed.
Dave
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
Marvin Gruber Mounting info needed for late BJ8 license plate holder Austin Healey 9
Jeepster BJ8 exhaust mounting points Austin Healey 17
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
G TR4/4A Silly Distributor Mounting Question Triumph 9
