TR4/4A Mounting after market TR4/A horns
tdskip
Hi guys - any pictures/sourcing recommendations/tips on mounting after market TR4A horns in the stock location?
My stock mounting brackets were missing when I picked up the car...
Thanks!
TR3driver
Great Pumpkin - R.I.P
The stock brackets were riveted to the horns. The few aftermarket replacements that I have bought came with brackets that would probably work, although usually designed for only one bolt instead of two. Eg, https://www.sourcingmap.com/pcs-car-auto-vehicle-12v-loud-horn-speaker-trumpet-p-64899.html
If you want something that will bolt to both holes, you'll probably have to fabricate it yourself. Any hardware store, Home Depot, etc. should have some flat iron that you can drill and cut to suit.
As Randall said for aftermarket horns I would make brackets. Originals were triangle shaped flat metal pieces. About a half inch hole at the point were the horn mounted and three holes in the back to mount to the car. Only outer two used to bolt to the car. I can probably get you a picture tomorrow or even a couple of original brackets. They are small, about two & half long where hey mount on car , then three inches out to rounded point. Your aftermarkets I'm sure will not be lucky enough to mount correctly.
Marv
HerronScott
Randall and Tom,
I thought that my TR4A horns had a removable bracket but you are right that I don't see a part number for it in my SPC.
Scott
T
tdskip
Hi guys - thanks for the info.
My MGC (whose horns are dead) as a removable bracket with the exact size holes for mounting, but of course it is angled completely wrong. I'm pretty sure I cannot bend them to be right without making a mess of them.
I'll just plan on fabricating something - thanks guys!
mrv8q
Hey, Tom I picked up some aftermarket high/low horns at Pep Boys for my 6, Fiamms, as I recall. They came with everything needed to directly bolt into the spot where the old horns were. Don't know how the 4 differs from the 6 regarding horn location.
mrv8q
Geo Hahn said:
Now you sound like a Fiat (not that there's anything wrong with that).
No, they're not too Fiat-like, more mid-tone, and LOUD!
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
G TR4/4A Silly Distributor Mounting Question Triumph 9
J Mounting 3000 engine to stand Austin Healey 7
