Mounting a hardtop question
Norton47
Hi everyone
Just got back for being on the road and have finished my rear fender rust repair. Am now mounting a hardtop for the first time.
Question is about the rear side seals TRF part #GP22.
Do they mount vertically so the curved lip seals against the rear deck forward extensions or flat and act as a cushion between the hard top and the top of the rear deck forward extension? This is hard to describe, the they would not cushion,the horizontal or flat way they would cushion between the top and the body.
Thanks
Good question, I couldn't figure that one out either. I just left them out. Didn't want to scew them up putting them in wrong. Phil
Hey 47 ,don't know if I have asked you before . Where in Wa. are you?
Don
Having just put on my hardtop yesterday...
They mount vertically. They aren't really a cushion, but are more of a sweeper.
I've always liked the look of a TR6 with the factory hardtop, but I never had one. A couple months ago I picked up a rough factory hardtop (see attached picture). Stripped, filled, primed and painted it. Bought new rubber and installed the glass, mounted it and drove about 100 miles yesterday. The car is quiter, visibility is great, and even though my six is a daily driver, it got more thumbs-up and stares than usual yesterday. With a shiney top it doesn't look like 'just another two-seater'
Thanks alwaysride
I ended up trying one that way and understand the sweeper comment. I also go some new window black fuzzy and bulb seals for around the windows but they seem to have the bulb seal up high on the u shaped channel moving it away from the window rather than at the bottom of u channel. My windows just reach the existing seals. I would like them to be a 1/4 inch higher or the top lower. Do you have this issue?
Yes, I had the same issue with a gap above the windows, so I went to my local auto parts place and picked up some generic auto weather seal.
I'm going to try to attach a couple pix I just took.
Again, this is a driver, not a looker. About a year and a half ago I bought 2 1972 TR6s, put the best into this car and sold the rest. I drive it year round here in Massachusetts and do my 50 mile round trip commute to work almost every day.
I had the same issue with the windows not reaching the top window seals. Thinking there must be some sort of adjustment for the window upper stop I removed the interior panel of my passenger door and proceeded to run the window to its highest point (when you hear a thunk of metal hitting metal) and with a mechanics mirror could see that there is an adjustable stop. There is a very small bolt about even or a little below and about 6" behind the handle to open the door. I loosened that and was able to get the window up another 1/4" and get a propper seal at the window top. The driver side I didn't even remove the door handles. I was able to pull the interior panel in at the rear of the door to reach the bolt raise the window up and tighten it back up. It was a hassle, but not as big a hassle as removing the handles. Hope this helps, Phil
Phil again, Look at TRF spare parts catalogue volume 2 page 369 plate FE. Part 73 is the is the door glass stop. It's behind the inner door shell. The two bolts marked 74 hold the door glass stop, the front one acts as a pivot the rear one as the adjustment. Phil
Thanks Phil
WIll look at that this afternoon, lucky me I have the drivers door cover off from installing a new winder mechanism. /ubbthreads/images/graemlins/smile.gif
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Rear tonneau capping plates and bridge pieces for mounting the Hardtop? Triumph 3
D Hardtop mounting hardware Triumph 4
PeterK TR2/3/3A TR3 Hardtop mounting brackets Triumph 13
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
