GT6 Mk1 GT6 Alignment
dklawson
A bit of history on our GT6. It was raced by my father-in-law during the early 1970s. He lowered the car and I'm sure the camber, castor, and toe were changed. Years ago I put new bushings in the suspension when I restored the car. BUT, I only drove the car locally and since I didn't notice any driveability problems I never set the alignment.
The car has a brand new set of tires and my wife wants to drive it more frequently and on the highway. After her first trip she reported the car was smooth as glass up until 60 MPH and developed a shake in the steering wheel above that. I seem to remember similar behavior on the old tires the few times I had the car up to highway speed.
I've searched here and I've read my factory manual on the settings. However, since the car has been lowered I doubt I'll ever see the factory specs again. Therefore, I have the following questions.
The factory spec for an empty car is 1/16" to 1/8" of toe-in. The camber was something close to 2 degrees positive (out at the top). The castor was also specified but I can't figure out how I'd measure it. Are there any easy ways to measure castor?
I'm OK with checking and setting the toe. However, is the camber REALLY supposed to be POSITIVE? That's counter-intuitive to me I'm also very confident (without measuring yet) that the car currently has negative camber. However, if the car is supposed to have positive camber and if I remove enough shims to move it back into positive territory, what should I aim for? With the short front springs I doubt it will ever go to 2 degrees positive. If I ended up at something close to zero degrees would that be “good” or “bad”?
Should I just focus on the toe and leave the camber alone? The steering effort is a bit heavy but not too bad. It DOES make ugly tire squealing sounds when making low speed turns at near full steering lock.
Again, how exactly are you supposed to check castor? How critical to driveability and tire wear is castor? I understand that this is adjusted by removing and installing shims to "pivot" the lower A-arm forward or backward but I can't imagine how you measure this. Should I leave a sleeping dog alone?
Lastly, so I don't go around in circles, is there a logical order to make these adjustments so they don't "fight" each other?
Thanks in advance for the advice.
Platinum
Castor angle is something you MAY be able to determine with a plumb-bob and protractor viewing the upright compared to the string. It really only affects the way the steering behaves to put the thing back to straight ahead when rolling. It "should" be a bit forward at the lower part of the pin for street driving. This, of course, with the suspension "loaded".
Positive camber would seem to me to be a bit goofy for a highway car, AND it can cause "hop" at speed with toe-in over 1/16" (IMO). A short contractor's level (the bubble kind) with a pair of screws of equal length tapped into it at wheel rim bead diameter can get you a guesstimate as to positive/negative/neutral of the set-up. "Degreeing" it can be done with a protractor and some patience.
I almost hate to suggest this, but: can you gain access to a laser alignment rig to see where it is at the moment? At least then you have a "base" to judge from.
And I'll assume you have ruled out a balance issue already.
V
vagt6
Doug, the rear wheels on a GT6 are supposed to have a degree or two of negative camber.
Go to the Yahoo Groups NASS board or the "GT6 Enthusiast" board and ask, very experienced folks there.
Also the Kas Kastner board is a big help. Mostly racer stuff, but they are very knowledgeable.
dklawson
dklawson
Thanks to everyone for your suggestions.
Mark, I already searched the NASS Yahoo group archives and over the past 2-3 years the only topics that come up about alignment don't focus on my issue. I had already posted the same questions there and the first response I received suggested that I focus on what the toe is if the car is otherwise driveable and the steering isn't too heavy. BTW, I'm concerned about the camber on the front wheels, not the rear.
Tom, I think the big issue is that the car was converted away from "stock" years ago and short of restoring all its suspension components back to stock I have to find a way to make it drive better with what I've got.
Dr., the tires/rims were just worked on. These are wire wheels with new Khumos installed by Hendrix Wire Wheel. Their practice is to true the wheels when possible, then shave the tires true, followed by balancing. Then they identify the best wheels and tag them for installation on the front. I have confidence in their work and as I mentioned, I think the 60+ MPH shake was there before the new tires.
I have no access to high-tech tools for alignment. I could always break down and take it to a shop. Even if I took the car to get the toe set, I'd want to have the camber sorted out in advance. There's no chance local shops would have the shims necessary for a 42 year old Triumph.
I also thought the positive camber sounded strange... but there it was in my manual. I'm 100% certain the setup at the moment has negative camber and frankly I like the idea as long as it's not causing the shake. I know that this is likely to accelerate the tire wear on the inner edge of the tread. However, I anticipate the tires "aging out" long before wearing out at the rate we drive the car.
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
B GT6 Mk1 GT6 glass domed fuel pump Triumph 6
dklawson GT6 Head Re-Torque - Mk1 GT6 Triumph 8
brgrmyster GT6 New Molded Carpet Set GT6 Mk1 & 2 For Sale Triumph 7
Eddie6775 GT6 Installing Fiero seats in My GT6 MK1 Triumph 24
dklawson GT6 Mk1 GT6 Engine Rebuild Triumph 36
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
R GT6 Need to see GT6 Mk1 Throttle linkage Triumph 9
Seabrook GT6 Pertronix in a MK1 GT6 ? Triumph 3
Seabrook GT6 GT6 MK1 Header? Triumph 20
P GT6 Gt6 Mk1 engine parts Triumph 0
Todd78d Sprit MK1 gear box filler Spridgets 2
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
K MK1 Cooper S? British Motor Corp 3
M General MG Midget MK1 windshield replacement MG 2
K Disc Brake Conversation to MK1 Midget Spridgets 2
D AH 300O MK1 Choke Knob Position Austin Healey 5
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
LarryK Jaguar MK1 restorations Jaguar 15
B 1959 mk1 3.4l jag Jaguar 4
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
S XJ6 Mk1 clutch slave question Jaguar 0
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
Csarneson Bargain 3000 Mk1 in Colorado Austin Healey 1
A Mk1 rear deck restoration Spridgets 0
A Chassis front 'H-section' Mk1 Spridgets 5
D Charging issue on mk1 British Motor Corp 1
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
R GT6 Mk1 Pulley weighting marks Triumph 6
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
C MK1 3000 fan belt Austin Healey 1
K 61 Mk1 auto to manual OD gearbox swap? Jaguar 0
N Bulb holder Mk1 3000 Austin Healey 5
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
C Mk1 3000 screen/windshield fitting Austin Healey 7
A Mini Mk1 dash heater knob British Motor Corp 0
C Servo fitting MK1 3000 Austin Healey 1
C Mk1 3000 side screens variations Austin Healey 13
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
D MK1 Rubber Tunnel Cover Spridgets 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
RickB MK1 Midge radiator value? Spridgets 2
I 2000 MK1 posted on CL Triumph 2
S MK1 midget measurements Spridgets 0
Boink Color Wiring Diagram for Mk1 Spridgets 8
