Bulb holder Mk1 3000
Neweys
Can anyone tell me the right bulb holders for the illumination of the oil/ fuel gauges ? I have lights to the speedo / rev, but noting on the old loom for these gauges. have bought the new brackets to secure the gauges which include a place for the bulb holder, but where do I get the actual bulb holder from ?
AUSMHLY
Send them an email and ask them your question. They'll let you know what the part number is and the cost. Good luck.
andrea
Assuming that your car is a evolution of my 100/6 1957 Instrument have this bulb inside - E 10 Socket
(NO commercial Interest)
(If you have a NEW/recent harness-- NEW lamps LG4705 can be mounted, but in my opinion this is a wrong choice) NOTE: LED with same E10 socket can be mounted without any modification (I have followed this solution, BUT my car is NEGATIVE Ground wired) Hope this helps
Hover over the image to zoom.
[h=1]BULB - INSTRUMENT LIGHTING (SCREW FIT) - LG4690[/h]
[h=5]Your Price: £0.50[/h] (ex. VAT)
Part Number: LG4690
Application: BN1-BJ8
Quantity per Vehicle: AR
Alt Ref: GLB280 (170-000)
Qty
Michael Oritt Bulb holder issue Austin Healey 5
N Correct Bulb Holder for BT7 fuel gauge ? Austin Healey 4
H TR4/4A License Plate Bulb Holder On TR4 Triumph 6
1 Bulb Holder Spridgets 2
jvandyke Gauge bulb holder; can it Spridgets 2
davidk Fuel Gauge Bulb Holder Needed Triumph 7
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
SherpaPilot TR6 Unidentified Bulb Triumph 7
E MGB Turn signal bulb MG 5
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
R water temp bulb loose Austin Healey 27
T TR2/3/3A rear license plate bulb number Triumph 4
K TR2/3/3A Headlght warning bulb? Triumph 1
trrdster2000 General TR Rear bulb holders. Triumph 4
CJD TR2/3/3A Headlight bulb rating Triumph 18
K TR2/3/3A Dash panel light bulb colour options? Triumph 5
S BT7 Dash Gauge Light Bulb Replacement Help Needed Austin Healey 16
Nelson Instrument bulb replacements Spridgets 14
S Wedge 1980 TR8 BULB Triumph 3
I Light bulb base resource? Triumph 1
Russ Austin Temperature gauge bulb stuck in thermost houseing! Triumph 10
hondo402000 New Old Bulb Holders Triumph 7
AUSMHLY 2.2 watt E10 gauge bulb Austin Healey 13
M 1275 need to install water temp bulb. Spridgets 6
hondo402000 H4 Bulb Wiring Triumph 7
theleisure Front Turn Signal Bulb Spridgets 6
jvandyke bulb holders? Spridgets 4
pjsmetana Spitfire Spitfire Taillights - Bulb Housing Corrosion! Triumph 8
C turn signal bulb type thing Spridgets 4
W Bulb holders ... does it matter ... Spridgets 2
R bulb wattage-BJ7 Austin Healey 8
Gearhead turn indicator bulb for a 74 Midget Spridgets 3
bobmga62 MGA dim bulb on MGA MG 6
George Zeck Turn Signal Light Bulb & Connection ..... Spridgets 1
C Looking for replacement turn signal indicator bulb Spridgets 1
C Replace tail light bulb Austin Healey 33
B Dash Bulb Replacement Spridgets 2
AUSMHLY Need the bulb number for the front and rear lights Austin Healey 2
AUSMHLY A brighter instrument gauge light bulb Austin Healey 59
RedTR3 Bulb Question Triumph 5
Jim_Gruber Need Light Bulb Socket / Turn Signal / Behind Dash Spridgets 1
jjbunn Bulb Removal Problem MG 12
S Temperature bulb removal Austin Healey 2
C taillight bulb MG 7
NutmegCT warning bulb questions Triumph 9
Brosky Brighter dash light bulb saga continues Triumph 17
T xk8 bulb failure message - help! Jaguar 5
