GT6 Mk1 Pulley weighting marks
Richter12x2
Finally swapping in the numbers-correct engine on our GT6 Mk 1, and was trying to pull the crank pulley off the one that was in the car, and I noticed that I can move the balancer back and forth on the rubber section, like the rubber has let go. I'm thinking that's probably not normal and we should be looking at a replacement.
The pulley is stamped R21121-B, and I found one on Ebay marked the same, but mine has 1 drillmark on the back, and this one has 4, so I thought I'd better check and see if it makes a difference.
Also considering the fancy shiny new one from BPNorthwest, if I'm looking at $100 + shipping for a used one that can fail at any time, $210 for a brand new may not be too bad of a deal, but they're indicated for the Mk 3 GT6 - would it be the same down into the Mk1's?
dklawson
The drill marks are almost certainly from balancing the rotating components. Since no two pulleys or assemblies are exactly the same, the number and location of the drill spots won't be the same. If you have a front pulley in good condition (i.e. The rubber has not perished or cracked.) then use it. You do not want to use one where the rubber bond has failed as the outer ring will be dangerous when loose and it won't be doing its job of dampening vibrations.
As you found, new ones are expensive but $210 isn't that bad compared to what they can cost for other British cars.
I'm glad you will be putting the original engine in. I wish I had been able to do that with our car.
R
Richter12x2
Thank ya sir! I figured it was probably just from balancing the individual pulley, but I wanted to be sure.
R
Richter12x2
Yeah, unfortunately they look that way until you hit them with a propane torch and a screwdriver trying to get them to slide off the crank snout. :(
There's apparently like, almost a rubber band sized strip of rubber that holds the bigger part to the center. But the one from you're picture is the exact one I'm replacing. Now REALLY the rubber is still so tight that it doesn't fall off or anything, it'd probably last years before it managed to spin off or wobble, but my bigger concern is that means I can't trust the timing marks anymore.
tomshobby
The rubber would have to be nearly completely gone for the pulley to separate. This drawing shows the geometry of the outer pulley on a TR6 and the inner pulley matches it with about a 1/8" space. In other words there is little clearance for them to be separated.
Even if the rubber is loose they will not come apart. But the outer pulley can rotate and the timing marks could become useless.
If the rubber becomes hard and/or cracked the damper will not function properly. The rubber is designed to act as a spring to dampen the vibrations of the crank. The engine will run much smoother and efficiently if the damper is in good condition.
attachment.php
Todd78d Sprit MK1 gear box filler Spridgets 2
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
K MK1 Cooper S? British Motor Corp 3
M General MG Midget MK1 windshield replacement MG 2
K Disc Brake Conversation to MK1 Midget Spridgets 2
D AH 300O MK1 Choke Knob Position Austin Healey 5
Rut Wanted Bugeye, mk2, Midget mk1 windshield frame Spridgets Classified 1
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
LarryK Jaguar MK1 restorations Jaguar 15
B 1959 mk1 3.4l jag Jaguar 4
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
S XJ6 Mk1 clutch slave question Jaguar 0
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
Csarneson Bargain 3000 Mk1 in Colorado Austin Healey 1
A Mk1 rear deck restoration Spridgets 0
A Chassis front 'H-section' Mk1 Spridgets 5
D Charging issue on mk1 British Motor Corp 1
A When were turn signals original equipment on Mk1 Bugeye Sprites? Spridgets 4
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
C MK1 3000 fan belt Austin Healey 1
B GT6 Mk1 GT6 glass domed fuel pump Triumph 6
K 61 Mk1 auto to manual OD gearbox swap? Jaguar 0
N Bulb holder Mk1 3000 Austin Healey 5
M signal lamp replacement - 1960 austin-healey 3000 mk1 Austin Healey 6
C Mk1 3000 screen/windshield fitting Austin Healey 7
A Mini Mk1 dash heater knob British Motor Corp 0
C Servo fitting MK1 3000 Austin Healey 1
C Mk1 3000 side screens variations Austin Healey 13
C Healey 3000 Mk1 engine Vs Wolseley 6/110 Austin Healey 18
D MK1 Rubber Tunnel Cover Spridgets 3
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
ShawnC_at_Moss Spitfire New catalog includes Spitfire Mk1, 2 & 3 Triumph 6
RickB MK1 Midge radiator value? Spridgets 2
I 2000 MK1 posted on CL Triumph 2
dklawson GT6 Head Re-Torque - Mk1 GT6 Triumph 8
S MK1 midget measurements Spridgets 0
brgrmyster GT6 New Molded Carpet Set GT6 Mk1 & 2 For Sale Triumph 7
Boink Color Wiring Diagram for Mk1 Spridgets 8
C Trick Midget Mk1 Racecar Spridgets 15
Eddie6775 GT6 Installing Fiero seats in My GT6 MK1 Triumph 24
dklawson GT6 Mk1 GT6 Engine Rebuild Triumph 36
brgrmyster GT6 Anyone Parting a 67-68 GT6 Mk1 US spec Triumph 2
brgrmyster GT6 NOS Lucas heater fan switch 35560 - 67/68 GT6 Mk1 Triumph 2
K MK1 Seat Repair/Rebuild Triumph 5
C Some cool Pics of my MK1 Spridgets 25
J Fiberglass Fenders for Early Midget MK1 Spridgets 11
M bn-7 [mk1] block casting number Austin Healey 2
