Mainshaft Bearing Removal
mylesw
Hello
I'm most of the way through dismantling my side shift gearbox and am now trying to remove the bearing from the mainshaft but with little succes so far. What is the trick to get this off - my pullers are all too short to reach it...?
Thanks
Myles
BoyRacer
Get a proper puller. Hammers are for the people that don't use proper tools....and damage things.
roscoe
The two piece bearing spliter is best. All you really need to do is support the inner race of the bearing and press out the shaft. If you have a long enough piece of pipe that has a nicely squared off end and an ID to allow the shaft to pass through but will pick up the inner race of the bearing you might get there by using a brass hammer but a hydraulic or arbor press is really best. I do have a huge hammer collection but I am judicious about when I use them.
Keoke
roscoe;93 All you really need to do is support the inner race of the bearing and press out the shaft. If you have a long enough piece of pipe that has a nicely squared off end and an ID to allow the shaft to pass through but will pick up the inner race of the bearing you might get there by using a brass hammer but a hydraulic or arbor press is really best. .[/QUOTE said:
I agree. Zactly what I would do:encouragement:
BoyRacer
Confession time for me. Although I have been an attorney for 39 years, I have a checkered past. I dropped out of high school in 1962 and went into the Air Force. My AFQE results were very high and that got me into nuclear weapons school. Then, at Lowry Air Force base in Denver, Colorado, just prior to me starting nuclear weapons classes, they noticed I was a high school drop-out. Heaven forbid! I was relegated to auto mechanics school (special purpose vehicle maintenance) and sent to Chanute Air Force base in Illinois. It was there that I heard those memorable pearls of wisdom from one of my tech-Sargent instructors....."don't force it, get a bigger hammer".
I can honestly say.......... I never followed his advice.
Keoke
OMG This fella has lead a hard life.-Keoke-:welcoming:​
steveg
The one I heard was: "ya make it on until it strips, then back off a quarter turn."
Keoke
OH that's a good one Steve :
. Be sure and have Pete bring it up at the next Tech session, that is some valuable information -Keoke:jester:
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
jdubois GT6 Driving the mainshaft bearing into the gearbox case. Triumph 5
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY BJ8 Mainshaft Needle Rollers, 32 or 33? Austin Healey 6
R Overdrive dummy mainshaft Austin Healey 1
C 100-6 Mainshaft Replacement [1959] Austin Healey 7
G Does the 1500 mainshaft stick out past the bellhou Spridgets 11
germanmichel Standard clearance mainshaft of the transmission ? Austin Healey 3
C Bad Mainshaft - Ouch! Austin Healey 8
D Mainshaft 3rd gear end float MG 0
S TR2/3/3A Pinion tail bearing replacing Triumph 12
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
Got_All_4 TR6 Throw Out Bearing Fork Problem Triumph 7
C Spitfire rear wheel bearing Triumph 2
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
charlie74 TR6 Bearing cap bolts Triumph 8
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
C TR2/3/3A TR2 Axle/wheel bearing removal Triumph 2
T crankshaft (rear) bearing leak Spridgets 2
red57 Rod Bearing Clearances Austin Healey 4
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
K TR2/3/3A Bearing Failure? Triumph 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Lin Cause of burned wheel bearing? Austin Healey 5
J General TR Main bearing caps Triumph 6
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
B TR4/4A Front cam bearing Triumph 8
A Front wheel bearing issues Austin Healey 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
R Center Gearbox Input shaft bearing Austin Healey 9
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
B TR4/4A What really is the best clutch/bearing combo Triumph 4
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
M Wheel bearing question Austin Healey 9
JPSmit Midget Thrust bearing coonversion Spridgets 9
B Clutch Release Bearing Austin Healey 2
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
Bayless Need wheel bearing advice please Spridgets 4
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
