TR2/3/3A Macy,s new fan
donbmw
Is any one going to try the new fact Macy,s is sell now.
Don
GerryL
I have installed Massey' s new fan. I have a TR4 engine in my TR3 and had to install the shorter crank extenstion to provide sufficient clearance for the radiater. I also elongated the mounting radiater holes to pick up an additional 1/4 inch. The thick fan belt can now pass between the fan and the radiater. According to Mark Massey he has not encountered this problem and felt that I may have a TR4 front engine plate. Any time I had any questions, Mark Massey returned was phone calls and was very helpfull. The other complication was that the radiater whole for crank was positioned two inches too high when previously recored, and required a local radiater shop to relocate it. Will report when car is back on road.
Geo Hahn
A link for those interested (scroll down to): Hurricane Fan Blade
toysrrus
Geo; Did you buy "Marks Mounting Kit" as well?
How easy / accessible is it to get the old fan off & mount Marks fan with everything in place? Meaning, Rad. is in; Front Apron is in; In driving cond?
Thanx, Russ
Geo Hahn
I have not purchased this fan -- just posted a link and a pic from Mark's website to help round out the discussion.
I have replaced a TR3A fan with the radiator in place (but not using Mark's fan) -- but it was close work and might not have been possible with other than a stock fan.
HarryL
Just received the fan the other day. Only problem I see is flattening out the
tabs on the tab washers that retain the bolts on the existing fan assembly.
Haven't tried looking from underneath .
Oh ya, a 4A .
Harry
donbmw
donbmw
Let us know if you see any difference in cooling. I plan on change to their fan.
Don
HarryL
Ok. Removed the existing fan without taking out the rad. Will not do that again !
So today I removed the rad to put in the new fan.
Tomorrow will put the Macy's fan on the car. One problem that I
do see is that The Macy mounting kit is the same as you would get from other sources.
The hub on the Macy's fan is thinner so I believe you would need to trim the rubber
grommets to make them fit. Will call Macy's tomorrow for advice.
Harry
toysrrus
Hi Harry,
I have to guess that you had to remove the "Front Apron" as well; Correct?
Russ
HarryL
We're talking a 4A here. Just disconnected the hoses, unbolted the side brackets,
bolts holding the base; and carefully lifted it up and out. Oh ya, had to disconnect the top hose with
the thermo housing connected.
Harry
BillyB62
I just bought Macy's Hurricane fan as well. As soon as my house renovation project is complete, I will start my "winter" maintenance on my 3A. I'll update everyone with my progress as well. I did speak with Mark via email, he suggested that I do not install the auxiliary pusher fan I bought last fall and had not installed yet - claiming the cooling system will not need it once the Hurricane fan is installed and in his opinion the restriction the fan would cause would hinder the performance.
toysrrus
Hi Kiowacraw,
Personally; I can`t wait to hear your exp. Will you be installing the Fan with the "Front Apron Off or On"?
Thats the part that most interests me as I`m "NOT" going to remove mine.
Keep us all posted.
Thanx, Russ
I just received my fan in the mail today. I will let you know how it goes.
Kiowacraw
Russ-
I will try everything possible to avoid taking off the apron. Even if it means sending in my three year old daughter's skinny little arms in there. :smile: I will let you know how it goes.
Kiowa
PeterK
If you leave the radiator in-place, tape a piece of cardboard over the radiator fins while you work to protect them and the back of your hands as well.
HarryL
The fan is a real winner !!!
Took the 4A for a ride this afternoon in about 85 with no clouds. Ran it hard for about 30 minutes,
slowed down into traffic and eventually went thru about 6 long light. Lugged it in 3rd for a bit.
Temp guage was a little over 1/2 way & when I got into the stop and go went up to about 3/4.
Dropped right after moving again.
Harry
donbmw
donbmw
I guess I will have to get one.
toysrrus
Hi Peter,
Yeah, "For Sure"!!
Russ
Hey Mark M.
If your reading this; I hope you have a good inventory of fans!! I can surely see one coming to me soon!!
"Harry": Thanx much for your input. Sounds pretty good to me!!
Russ
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
jfarris TR2/3/3A Installation of a Macy's Hurricane Fan Triumph 13
5 TR2/3/3A Macy's Garage restoration done and having fun Triumph 6
Darrell_Walker TR4/4A Macy's Garage TR4-6 bonnet release kit mini-review Triumph 24
Twosheds Mark Macy at 2009 TRA Meet Triumph 3
mctriumph TR2/3/3A Ultimate fan conversion Triumph 10
F Revotec Fan Austin Healey 2
S Installing a Radiator Fan Austin Healey 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
tr6nitjulius General TR Fan Belt Replacement '72 TR6 Triumph 1
RJS TR4/4A Radiator Fan Shround Triumph 3
KVH General Tech Fan Not Backward — Balancers Triumph 5
A Spitfire Install fan Triumph 1
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
R six bladed fan - bugeye Spridgets 2
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
Lin Fan belt for 1275 with alternator Spridgets 4
Tr3aguy TR2/3/3A Tropical Fan Triumph 19
G Thermo Fan Sensor Austin Healey 5
R TR6 fan shroud replacement Triumph 5
J BJ8 Radiator Fan Austin Healey 12
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
D Spitfire Electric fan Triumph 3
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
T BJ8 Fan Belt Change Austin Healey 7
B Wanted FOUND. TR10 Fan mount Bushings Triumph Classifieds 3
S Heater and fan control replacement - any advice? Austin Healey 9
B Fan Blade Failure Austin Healey 6
D Fan Blade Austin Healey 11
B Revotec fan kit Austin Healey 4
B TR6 TR6 Fan Belt Triumph 4
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
FlyingCat Spitfire Electric Radiator Fan Triumph 10
N Bumper bracket and fan shroud color Austin Healey 5
FlyingCat Spitfire Radiator and fan Triumph 5
