tony barnhill
Great Pumpkin - R.I.P
...& lest you might ever become one:
THERE ARE NO METRIC NUTS OR BOLTS ON AN MGB!
...NO, 13mm doesn't hold the air cleaner on a Zenith Stromberg
...NO, 11mm doesn't hold the heat shroud on a manifold
...NO, 19mm isn't the correct bottom bolt on a starter
...No, 13mm doen't hold the driveshaft to the 3rd member
...& if I find any more metric nuts/bolts as I continue disassemblying your old car, I'll hunt you down & feed your 1st born to the German "Unpimp Your Ride" mad scientists!
geez!!!!!
geez!!!!!
