Thor
It's been a while since I had to troubleshoot the mg and want to get ideas on where I should start looking for the following problem. At around 3000 rpm's I loose power as if the motor is maxed out.
The midget is a 1978 1500 and has been working well all Summer long without until recently I was cruising at 60 mph and the motor died. I was able to get it started with several episodes of cranking the starter but since then I've a real lack of power at 3000 rpm's.
My first thought was that the distributor slipped or something. I checked that this morning and its nice and secure. I also checked the timing and its about 13 ATD which from what I recall is where I set it at during tuning since it ran best at that setting.
So does anyone have thoughts what else I should be checking to see if that is causing the problem. Thanks for suggestions.
