Jim_Gruber
OK Starter removal not an issue until you get to the bottom bolt. Right now looks like the only way to get at that bolt is to remove the clutch slave and I know there is a way to do it without resorting to that.
So what is the trick, a couple of ratchets with a 12" extension bar on each side to get at it? And once you get it loose is there a trick needed to reinstall and tighten the bottom bolt..
HELP!!!
HELP!!!
