TR2/3/3A Will flatbed truck scrape bottom of TR3A ?
JonnyRotten
I need to tow my tr3a.Will a standard flatbed truck scrape the bottom of car on the way up and down being the car is so low to the ground?If so what should I do?
Mickey Richaud
Depends on the angle of the ramps. To help, you can place a couple of 2x6's under each rear wheel as you ease the car up the incline. Have someone watch to see when/if the rear drags. Just before it does, put the necessary 2x6's just ahead of the rear wheels. Worked for me.
pjsmetana
Or do what I did once... let the air out of all the trailer tires and jack the front of the trailer all the way up... then after the car is on it, pump all the tires back up and lower the trailer back onto the tow ball on the truck. Having a 12v electric tire pump in your truck is always handy :smile:
J
JonnyRotten
Ill ask the burly tow truck guy if heck let me let the air out of his tires and jack up the front of his truck.But seriously,I dont have a trailer.I need to hire a tow truck co. to pick it up.I had my van towed recently on a flatbed and the bumper hit the ground on the way down and its much higher than a tr3a.
Moseso
JonnyRotten said:
I called uhaul, inside to inside of ramps are 35".anyone know the width of tires on a 1960 tr3a..
My shop manual says 3'9", front and 3'9-1/2", rear. Too wide for that ramp, I think -- and probably overweight, too.
Many years ago I put the TR3 in a truck trailer, up some ramps. The driver and someone else pulled up on the rear wheel wells as it reached the critical point. It lifted the car enough to get it in & back out without too much noise.
AlWallace
I had my 3a moved with a flatbed. I had no issues. The tailpipe was close but using a 2x6 piece of wood to elevate the left rear tire did the trick on and off the bed.
Al
TR4nut
Most towtruck drivers have roughly 3' lengths of 2x8s or 2x10s just for the purpose of helping with the angle - that should work pretty easily if you need it.
I used a UHaul car hauler to haul my TR4 a couple of years ago, it just fit with a little room to spare - the TR3 is I think 3" narrower so it will be an even tighter fit but I think with some care it will work.
DNK
As Randy said. If they don't have them I don't know if I would want them touching my car
TR3driver
Great Pumpkin - R.I.P
Depends on the tow truck, IMO. The longer the bed extends, the less angle it makes with the ground and the less likely the car is to drag.
The problem is not just how high the car is in the back, but how far the body extends behind the rear axle. Your van sticks out a lot more than the TR3! My Stag was about equally likely to drag bottom in my driveway as the TR (before I lowered the TR), and it had no trouble going onto the flatbed that AAA sent out a few years back.
The 3'9" figures quoted above are the "track", meaning center of tire to center of tire. The actual clearance between the sidewalls is somewhat less. With stock rims & tires, it's probably only 39" sidewall-to-sidewall ... which will still fit fine on that 35" ramp if you are careful to line the car up perfectly. I've even done it with part of the tire hanging out in space, but of course that requires even more care to be sure it's perfectly lined up and stays that way.
Gordon_Dedrick
Had my TR3 on a tow truck more times than I care to remember but I never had any issue with a rollback incline tow truck. Winched right up without any problem. Just be sure they know how to secure cars like these as there are no tow eyes!
On another occasion I rented a U-Haul car trailer and chickened-out when I saw how narrow the tire rails are. The TR3 track BARELY fits the rails. Feathering the clutch while trying to drive up was just too much for me. You are really better off with a completely flat floored trailer.
Check with the guys in the local TR club.......bet someone has a trailer........ or call AAA if you belong.
Gordon
tdskip
Or you can use a come along to winch it up if driving it isn't desirable (it is tight).
SkinnedKnuckles
I almost hate to ask - where're you going?
AngliaGT International Flatbed Spotted 0
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
aeronca65t Flatbed Ford Spotted 16
Nelson Home aboard a flatbed! Spridgets 9
JPSmit Today's journey great start - home on a flatbed Spridgets 39
tateboys Tow Dolly vs. Flatbed Trailer MG 42
B My first date with a flatbed/Burlingame Specialist Austin Healey 5
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
AngliaGT Cool Old Truck + Spotted 1
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
S TR2/3/3A my son's truck Triumph 2
S My son’s truck Other Cars 3
GTP1960 A fine lookin truck. Other Cars 3
GTP1960 Spotted this old Chevy fire truck in Porto Portugal Other Cars 3
PAUL161 6.0 Power Stroke Ford Truck Other Cars 4
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
tinman58 TR5/TR250 Side effect of a big truck Triumph 3
RickB A Truck sent rocks flying my way this morning. Spridgets 9
JPSmit Chevy Truck - and Lada Niva Spotted 0
aeronca65t Tesla + Chevy truck Spotted 0
RickB Budget renat a truck [NMC] Spridgets 12
AngliaGT My Old Truck..... Other Cars 3
racingenglishcars Morris truck Other British Cars 1
Brooklands Mini Cooper Pick Up Truck British Motor Corp 2
A TR2/3/3A TR-3A truck X brace rubber Triumph 2
glemon 800,000 ford truck Other Cars 9
jackq 47 1 ton Studebaker truck Other Cars 10
JPSmit Epic truck restoration Other British Cars 2
Marvin Gruber MGB Truck load of MGB parts MG 0
JPSmit Snow thrower truck Spotted 9
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
G Ford Truck Help?? Other Cars 2
bigjones Tow truck blues - good analysis for you to ponder Spridgets 33
P Can't get the truck to open Jaguar 29
Sherlock A rather odd truck/motorhome Other Cars 0
Bruce Bowker Dump Truck Other Cars 0
jackq Chevy truck Other Cars 7
PAUL161 RAF truck? What is it? Other British Cars 22
Glen_B Finished Morris truck photos Spridgets 16
Glen_B New truck hits the road Spridgets 11
Glen_B Photos of the Morris truck resto. Spridgets 9
vping Brake flush on my Truck Other Cars 19
S Neat Old Truck #2 Other Cars 5
Sherlock Neat old truck Other Cars 4
AngliaGT Magarus Truck For Sale Other British Cars 10
Sherlock What kind of truck is this? Other Cars 10
Banjo Anybody got a CHEAP truck? Other Cars 5
jackq MGB/1915 Ford Truck Restoration & Tools 0
Bret New Titan truck; What no power mirrors? Other Cars 1
jackq truck Other Cars 9
