TR2/3/3A my son's truck
sp53
I post on the “other vehicle” side and need help. Anyone know anything about Ford ranger trucks, fuel pump.
thanks steve
CJD
There should be a schrader valve on the fuel manifold (I'm assuming it's a later fuel injection??) . The pump should run for 2 seconds after turning the key from off to run...if there is no pressure, then the pump is not working. The order for fuel injection troubleshooting would be:
1) Find the inertia switch and make sure it is not tripped.
2) Find the fuse and make sure it is not blown.
3) Check the power lead to the pump during the 2 second run and make sure it is getting power to the pump.
If all that checks good, then replace the pump. Most fords require that you drop the fuel tank at least partially to reach the pump at the top. It usually installs with a rubber seal and a lock ring. Once the tank is down the replacement is not that hard. If you have my luck, then you just filled the tank before the pump went out!?!
S
sp53
Thanks John for your note, I do have it on the other car forum “of this forum” because of the quality of the mechanics here, but out of respect I try and only post for Triumph here. The pump will run hotwired.
My son’s truck is a 97 Ford Ranger with a fuel delivery problem. The pump has 4 wires- black, red, yellow, and green. When I measure voltage at the pump I get 12 volts at the yellow with the key on. When I hook power to the red and black the pump will run. I replaced the ignition; still no joy. My thoughts are to hold the key to the start side and see if I get power on the red post and to perhaps replace the key side of the ignition. I cannot find a fuse but did find a relay and traded one over with corresponding numbers, still nothing. Any ideas?
Thanks steve
S My son wrecked his 97 Saab. Other Cars 9
RickB Our loss, our oldest son Josiah Bastedo. Spridgets 25
glemon Finally Got a Car for My Son Subie Other Cars 2
weewillie my son got this yesterday and if anyone can help Other Cars 6
AngliaGT TR6 Son's TR6 is in.......Poland Triumph 3
RickB Off to Whale Pass AK for some fishin with my son! Spridgets 9
BOBBYR My son's first time driving a healey. Austin Healey 9
PATR8 Son's 240 is looking pretty good Other Cars 5
T A new project for Young Son..... Other Cars 17
PATR8 Whille looking for a car for my son I found these Triumph 4
angelfj1 "Son of TRusty" on eBay ??? Triumph 5
T Son of Crypt Car-Up-date? Triumph 5
Steve A call from my son..... British Motorbikes 10
M MGB young son riding in MGB MG 23
T Son of Electrical Stuff Triumph 2
Wana If my 14 year-old son had my Healey... Austin Healey 18
jaybird My son's Midget Christmas Wish List Spridgets 16
jaybird Son bought a Midget today *DELETED* Spridgets 9
T Son of Torque Wrench Restoration & Tools 2
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
AngliaGT Cool Old Truck + Spotted 1
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
S My son’s truck Other Cars 3
GTP1960 A fine lookin truck. Other Cars 3
GTP1960 Spotted this old Chevy fire truck in Porto Portugal Other Cars 3
PAUL161 6.0 Power Stroke Ford Truck Other Cars 4
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
tinman58 TR5/TR250 Side effect of a big truck Triumph 3
RickB A Truck sent rocks flying my way this morning. Spridgets 9
JPSmit Chevy Truck - and Lada Niva Spotted 0
aeronca65t Tesla + Chevy truck Spotted 0
RickB Budget renat a truck [NMC] Spridgets 12
AngliaGT My Old Truck..... Other Cars 3
racingenglishcars Morris truck Other British Cars 1
Brooklands Mini Cooper Pick Up Truck British Motor Corp 2
A TR2/3/3A TR-3A truck X brace rubber Triumph 2
glemon 800,000 ford truck Other Cars 9
jackq 47 1 ton Studebaker truck Other Cars 10
JPSmit Epic truck restoration Other British Cars 2
Marvin Gruber MGB Truck load of MGB parts MG 0
JPSmit Snow thrower truck Spotted 9
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
G Ford Truck Help?? Other Cars 2
bigjones Tow truck blues - good analysis for you to ponder Spridgets 33
J TR2/3/3A Will flatbed truck scrape bottom of TR3A ? Triumph 13
P Can't get the truck to open Jaguar 29
Sherlock A rather odd truck/motorhome Other Cars 0
Bruce Bowker Dump Truck Other Cars 0
jackq Chevy truck Other Cars 7
PAUL161 RAF truck? What is it? Other British Cars 22
