So, I've mentioned this before but it is driving me nuts. I turn on my headlights and turn on my signals and my headlights turn off. This happens mostly with the left signal. It doesn't seem to happen with high beams. The headlights are on relays. I thought it might be a ground issue as the relays and the signals were on the same bolt. Took the relay grounds and put them on another bolt - dielectric grease all around. It's better, now it only happens 1/2 the time. Usually it goes away when I wiggle the switch. I suppose I may be answering my own question with that last bit of information, but, it doesn't really make sense. If it is the switch, can it be dismantled? repaired? any other ideas?
thanks all
thanks all
