Nelson
My car runs as good as I would ever want it to run. That is true for only 15 or 20 minutes though. Then it suddenly runs very ragged and very soon just quits. At that time it will not restart and if it does it is just barely staying alive. Later in the day it will start and once again run great for a while. I have replaced the coil, the points, distributor cap, rotor and fuel pump. After each of these replacements the same scenario would be repeated. Today I pulled the plugs after it had died yesterday and they were carboned up. I cleaned up an older set of NGK BP6ES plugs and put them in. The engine started, with difficulty, and ran but was very rough and actually shaking. Yesterday when it died I checked both of the SU fuel bowls and they were full. I also used a spark tester at all of the plug wires at the plug end. They all had a good spark. The plug wires are Bosch and only several years old and look to be in excellent condition. This is driving me nuts!!! What am I overlooking as a cause for this?
