I'm Stumped [Interior Panels] ......
George Zeck
Hi All -
Pretty frustrated at the moment. Trying to recover the interior panels & trim for the Sprite.
Have re-cut new masonite (glorified cardboard) using the old ones as templates. Even used a slightly thicker piece versus the others.
Purchased a 22 gauge air stapler (real light staples vs. normal 18 ga) using the smallest at 1/4" deep staples and they poke through a little bit.
Tried a hand stapler - not enough power to push into the masonite.
Tried glue on some of the trim and the clamps left marks and after 2 days - have not disappeared. Afraid it's a permanent mark - thus having to re-do (again).
Tried local upholstery shops (before all above) and after missed appointments (took off from work to show at a pre-arranged time - no show), too busy to do such a large interior for 3 months, and general untrusting local folks - no reliable folks in my area.
I'm hoping it gets stolen. All while I'm wasting great driving time for my 3 month window in this part of the country.
Any ideas or past experience really would be appreciated at this point.
Tx-
George Zeck
Platinum
The padding I used is the thin closed-cell packing you can get at any "We-Mail-It!" place. The backing is a 3/16 polycarbonate plastic in lieu of the pasteboard OEM stuff. The attachment method was Weldwood Contact Adhesive. On the "back" side where the staples would have gone. NO staples, no "poke-thru" issue. You ~WILL~ need to pre-drill the holes in the plastic, tho.
Avon Lake, huh? GOTL "townie" here.
sqbsprite
I use 1/8 hardboard that can be bought at Lowes or HD. Brush contact cement on board and foam - allow to set then attach foam to board. Trim the foam to the size of the panel. Use 3M spray contact cement on foam and vinyl. Lay vinyl on foam. After it has set flip panel over and use brush contact cement and fold over edges of vinyl. You will need to make small slices around corners. If applied properly, the contact cement will hold it well. Don't rush it. The cement should be dry to the touch before you put the two pieces together.
Early cars had no padding, but the technique would be the same, just leave out the foam. The Moss panels use 1/8" plywood which seems to work well, but is hard to find. Drill holes in the panels first then you can poke thru the vinyl later. It is a good idea to trial fit the panels to the car first before you cover them.
zimasprite
I used the masonite but a little thicker foam. I used the 1/4" staples and some marine grade vinyl from an upholstry store. Sometimes the staples wouldn't have enough umph to go into the masonite, but typically did work well. In a few areas, I used a hot glue gun to attach things. I feel like it came out looking pretty good.
- Drew
sqbsprite
Hot glue would probably work well for the edges on the backside. You just don't want it to be too thick. I think the staples will come out after a while, but I have seen then used on the back side of some panels. Whatever works best is up to the user. Just experiment.
George Zeck
George Zeck
Just was able to find 5/32" staples for my new upholstery gun. Tested it on a sample piece. All good.
Kinda had my mind set on staples: A) it was what was in there before, B) Think glue would give out much earlier than staples, C) Easier to install (can remove and restaple vs. glue sets quick).
Will keep posted. Still unsure on how to post pic's (size issues) otherwise would like to post my progress. Will figure how to eventually from my ISP.
Thanks all -
George
jlaird
Glue on mine, contact cement, lasted 48 years.
spritenut
3M #74 spray glue for the front of the panels and vinyl.
2 coats of FLAMABLE contact cement on the back edge of the vinyl and the back of the panel, coat the whole back twice to weatherproof it. When the cement is try, stick it and it is on for a few decades.
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
JPSmit Horns - I am stumped Spridgets 14
JPSmit I'm stumped - wiring Spridgets 2
Lin Name this part - I am stumped! Austin Healey 24
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
BJ8Healeys This one really has me stumped! Spridgets 4
KVH TR4/4A Stumped Again on Carbs Fouling Plugs Triumph 16
F TR6 starter problem...totally stumped! Triumph 9
S General Tech MIdget Clutch- Totally stumped. MG 2
S MIdget Clutch- Totally stumped. Spridgets 6
Nelson Engine dies - I'm stumped Spridgets 30
B Stumped on Electrical Issue Restoration & Tools 6
JohnnyO I'm stumped... Spridgets 11
6 stumped...engine charging...or not Triumph 12
KVH TR4/4A Stumped on Electrical Wiring--TR4A Triumph 7
JPSmit I'm stumped - headlights/ signals Spridgets 26
6 Stumped: Fuel Pump Austin Healey 7
B MGB stumped by a 74 MGB MG 11
Morris I am completely stumped! Spridgets 30
8 STUMPED AND STUMPED AGAIN Triumph 6
fmichaels not stumped yet .. but Spridgets 26
M Stumped Again MG 12
S Stumped - Help! Other British Cars 12
Stewart Help Brake servo has me stumped MG 3
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
KVH General Tech Reinstalling TR4A Interior Triumph 13
Mickey Richaud Wanted Interior Austin Healey Classifieds 2
W TR2/3/3A Interior and Body Colours Triumph 14
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
K 100-6 Interior Austin Healey 4
MGTF1250Dave T-Series Interior Trim Panel installation MG 12
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
H 100-6 Interior Installation Austin Healey 4
nichola TR6 Interior panels Triumph 5
F Interior Door Handle Removal Austin Healey 2
S TR2/3/3A carpet kit and the interior done Triumph 8
B BJ7 Interior Finishing Details Austin Healey 2
rjc157 Wanted 76 interior Triumph Classifieds 1
77MidgetMkIV New top and interior-that escalated quickly! Spridgets 9
C XK120 Interior... and Interiors in General Jaguar 17
B TR4/4A Midnight blue interior Triumph 6
T Interior Door Panel and Top Rail Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
