Hawkscoach
Hello to everyone and hope you can help. Years of restoring a late 59 AH BN4 100-6 and finally running/stopping, painted etc. and starting the interior...purchased interior from Moss and have called them with this question-they could not answer.
Interior-rear wood/vinyl piece at rear wheel well just behind the door pillar (where the door latches). How does this piece attach? I understand these are different than early 59's and earlier years. I have one (only one side remained) "original" solid wood piece that seems like it would work as it has the correct length and angles and appears to have a "groove" where the panel would set into.......however, I cannot seem to find a picture or any information showing if this is correct and how all this goes together. There is no part listed in the Moss catalog and the call to Moss seemed to confirm it is not available through them. I can probably make these (having the one as a guide), but I want to make certain this is correct and how things attach. The rest of the interior appears logical and I feel comfortable assembling. Hope this makes sense to someone on here and thank you in advance for any help. I can try pics if it would be helpful.
Regards,
Doug
Regards,
Doug
