Stumped on Electrical Issue
Bob60
Member
Any electrical engineers out there. . .?
I'm generally pretty handy with electrical repairs - you pretty much have to be with several British cars but this one has me stumped.
Item: Spring loaded rocker switch that will make a circuit only when pressed then snap back to off - used on a Jensen Interceptor to activate a solenoid which opens the fuel filler flap. It had begin to only work occasionally.
Diagnosis: Removed switch, hooked up 12v power supply and tested - sometimes switched full 12v, sometimes only switched something like .8v. Figured it was grungy inside so I carefully disassembled switch and cleaned all the contacts with metal cleaner - See photo 1 - and reassembled.
Problem: Now, 3.1 volts bleeds through the switch even when in the "off" position. Disassembled again and took the guts out to make sure I hadn't put it back together incorrectly. The two spade terminals are not connected in any way, yet 12v supplied to one terminal will feed 3.1v to the other terminal. See photo 2.
I've done all my own Lucas electrical work for 40 years and I do not understand what is happening here?
Any opinions?
Photo 1
Photo 2 - how can this be when these are not connected in any way?
Thanks,
Bob
'73 Jensen Interceptor
various others
Roger
Bronze
Well, of course they are connected, although that which connects them is supposed to be an insulator. I imagine it no longer insulates fully - maybe something on the surface you could clean off, or just maybe the insulation properties of the switch material, bakelite or whatever, are breaking down.
I had a rotor arm do that to me once - start leaking to earth through the distributor.
Bayless
Did you add a little grease inside? If so maybe you used the wrong stuff, conducting vs insulating.
David_Doan
your dvm has very high input impedance - meaning it can measure voltage across a very high resistance. the cleaner you used is probably slightly conductive but nothing worry about on a 12v system. To verify, disconnect the 12v source and just measure the resistance across the switch, it will probably be greater than 1M ohms.
TR3driver
Great Pumpkin - R.I.P
I agree entirely. Assuming your DVMs has a 10 Megohm input resistance, we can even compute what the switch resistance at approx 30 Megohms. That means the leakage current through the switch will be way down there, less than a microamp. Nothing to worry about.
To verify this, hook up something as a load, perhaps a small test light.
(PS, I'm not exactly a EE, but close.)
B
Bob60
Member
Update -
I hooked up a small 12v test light and, as you predicted it would not illuminate. But the DVM still read 3.1v. I put a little carb cleaner on a q-tip and cleaned the contacts, dried with compressed air, and cleaned it again with denatured alcohol and again dried with air. Hooked up DVM and .01v bleed!
Amazing how a miniscule amount of cleaner residue can conduct current.
Thanks for the suggestions. Now I can get my fuel filler flap working again.
Bob
KVH TR4/4A Stumped on Electrical Wiring--TR4A Triumph 7
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
JPSmit Horns - I am stumped Spridgets 14
JPSmit I'm stumped - wiring Spridgets 2
Lin Name this part - I am stumped! Austin Healey 24
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
BJ8Healeys This one really has me stumped! Spridgets 4
KVH TR4/4A Stumped Again on Carbs Fouling Plugs Triumph 16
F TR6 starter problem...totally stumped! Triumph 9
S General Tech MIdget Clutch- Totally stumped. MG 2
S MIdget Clutch- Totally stumped. Spridgets 6
Nelson Engine dies - I'm stumped Spridgets 30
JohnnyO I'm stumped... Spridgets 11
6 stumped...engine charging...or not Triumph 12
JPSmit I'm stumped - headlights/ signals Spridgets 26
6 Stumped: Fuel Pump Austin Healey 7
B MGB stumped by a 74 MGB MG 11
Morris I am completely stumped! Spridgets 30
8 STUMPED AND STUMPED AGAIN Triumph 6
George Zeck I'm Stumped [Interior Panels] ...... Spridgets 7
fmichaels not stumped yet .. but Spridgets 26
M Stumped Again MG 12
S Stumped - Help! Other British Cars 12
Stewart Help Brake servo has me stumped MG 3
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
