I bought the HDVA conversion after doing a lot of dollar comparisons. I liked the idea of a fifth overdrive gear, and originally thought that the TR overdrive tranny would be the way to go, especially since it can be made to work on second, third and fouth gears, essentially turning it into a seven speed box. My original four speed needed work, so I could have done that, or traded it into Quantum and got an overdrive unit for about $2300. The other alternative was the Sierra five speed conversion costing even more at about $2800 from Dr. Marty on e-bay. Quantum wants even more for that conversion. That left the HVDA conversion at about $1600 plus the cost of a W58 Toyota. I bought that for $250. There's a reason those trannys are so cheap...supply and demand. They don't go bad. They will handle over 200 horsepower. I don't intend to poke that much power from my TR3, but I will be upping it some, and not having to worry about tranny problems because of the weaknesses of the original is a plus as TRBOOST points out.
The other cost considerations involve the fact that Herman supplies the clutch driven disk and the throw out bearing. Moss sells those two items for about $130...money that you won't have to lay out. Let's face it, if you're pulling the tranny, you're gonna replace those items.
So, after all is said and done, I'll wind up with a modern five speed for less money then a TR w/overdrive and all of it's short comings and problems. The beauty of this conversion, is that it is totally reversible if you so desire.
I'm doing a lot of resto-mods to the TR3. Rack and pinion steering, the HDVA tranny, and the Toyota 4-pot calipers. Why not. All those items needed work, so why not upgrade. Will it be a TR3 after all of this is done?? Not exactly, but it will make it more enjoyable for me. When I'm gone, and you want to put it back to original, I've got all of the original parts, and all you have to do is unbolt the mods and stuff in the old parts...after you get them refurbished. In the meantime, I'll enjoy what I'm doing. /ubbthreads/images/graemlins/thirsty.gif
/ubbthreads/images/graemlins/cheers.gif /ubbthreads/images/graemlins/driving.gif
