TR6 Installing HVDA transmission.
2wrench
Hello everyone! I am finally installing the W58 Toyota conversion from HVDA. I have received the conversion kit from Herman van den Akker and have placed the order for the "bent fingers" pressure plate. It should be received by the end of next week.
Herman has been quite helpful and supportive. His kit provided a DVD step by step instruction; however, there are some things, nonetheless, I still have questions on. Maybe some of you can be of help, as I do not want to hang on Herman's shirt sleeve for everything.
The DVD mentions upon lifting the new transmission into place, do not touch the flange at the end of the transmission as this could damage the rear oil seal therein. The comment I have most concern with is, "And if you turn the transmission flange, you're in trouble."
This concerns me. What is the "trouble" of which he speaks? In removing and replacing the flywheel, the engine turned, in tightening down the
bolts. Would this, in effect, put me into "trouble" in the same way as turning the transmission by its flange?
If I am in trouble, there must be a remedy. Any input? Thanks.
charleyf
I have done three of these swaps WITHOUT his DVD and the only thing that I can come up with is that you do not want to 'support" the transmission with the flange. But just touching it to turn the gears inside for alignment should not be a problem.
Charley
PeterK
Agree with Charley but if you've got 20 minutes, give Herman a call (he likes to talk and is a wealth of information.)
TRFOUR
I thought he had gotten out of the business of selling the kits. Has he restarted or did you have a kit?
martx-5
The latest issue (Sept. 2015) of Classic Motorsports has a quarter page advertisement for Herman's kit. I would think that he is still in business.
tinman58
Hey Dennis
I am near you in Brentwood. I have installed the HVDA in my TR3 I could head out too Tracy and give you a hand. I am retired so any time is good.
M_Pied_Lourd
Hey Dennis
Now there is an offer you can't refuse :smile:
Cheers
Tush
2wrench
2wrench
Wow! Thank you for such a nice offer. I did not follow up on these last posts, so I missed this post. I will be working on my car today and would very much appreciate any help. It has been so long since I have posted on the Forum, I am rusty. I would like to post a picture, and we should probably exchange contact information via personal message, which again the process escapes me. I'll continue to poke around and contact you. Thanks again!
2wrench
2wrench
He recently sold me my kit, so I have to say he must still be doing this. Also, he mentioned he had a few other kits to deliver when preparing to deliver mine.
2wrench TR6 Issue Installing HVDA transmission. Need your input. Triumph 6
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
