hood or bonnet whichever you prefer
radibob
The last time I pulled my engine on my 66 sprite when I replaced the bonnet the back of it is about 3/4 of an inch lower than it was or should be. I've fiddled with it and concluded i have no idea how this happened or how to fix it. Any ideas?
Thanks
Billm
On each hinge there are 4 bolts. Two that are "forward" and two that are "rear"
If you put washers between the hinge and the hood on the "rear" holes you will raise the rear of the hood.
If you put washers between the hinge and the hood on the "forward" holes you will lower the rear of the hood
BillM
R
radibob
OK so I'm thinking there were probably two washers on the rear bolts and none on the front and then I put one on each bolt when I put it back together.
Thanks
Billm
It doesn't adjust the hood if the washers touch the bolt head, the washers MUST go BETWEEN the hinge and the hood.
Bill
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S Forward opening hood / bonnet Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
anarchy99 Bonnet / hood fit question... Spridgets 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
G TR4/4A Random Hood/Bonnet Question Triumph 6
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
JPSmit Separate Thread - A40 Somerset hood [Bonnet] ornament Other British Cars 0
HealeyRick Bonnet/Hood adjustment Austin Healey 3
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
T TR2/3/3A Dzus on Bonnet [hood] - Is there a spring? Triumph 4
B Sunken hood/bonnet Spridgets 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
RJS Emergency hood/bonnet release Triumph 22
J Aerocatch style bonnet catch for flip-front hood Spridgets 6
P TR4/4A Need help with TR4A bonnet/hood mount problem, thanks! Triumph 4
T Hood / Bonnet Louvres Austin Healey 6
AH67 Steel Louvered Bonnet/hood for Austin Healey 3000 Austin Healey 1
P Spitfire SPITFIRE HOOD/BONNET LATCHES NEEDED Triumph 3
A Bonnet [hood] prop attachment Triumph 16
C Berkeley Hood/Bonnet ornament Restoration & Tools 13
jvandyke hood [bonnet] release broken cable Spridgets 34
O 1960 Healey 3000 BN7 front hood/bonnet Austin Healey 2
G Replacement of Bonnet/Hood Hinges/Gaskets/Hardware Triumph 5
P Bonnet Hood Prop Triumph 2
JPSmit Hood [Bonnet] release question Spridgets 1
jvandyke hood bonnet prop rod Spridgets 4
BobbyD TR6 TR6 Hood/Bonnet Install Triumph 2
M TR4/4A Wanted: TR4 Hood [Bonnet] Triumph 6
W Rattling hood/bonnet MG 4
neilh Hood [ bonnet] alignment - or lack of! Spridgets 12
jjbunn Bonnet/Hood Plunger MG 7
jjbunn Hood/Bonnet props MG 27
S MGA MGA Bonnet [Hood] adjustment. MG 7
bcbennett Hood [bonnet] alignment Triumph 6
cheekygeek MGB MGBs for Dummies: How to open the hood/bonnet MG 9
78Z Added gas struts to hold up hood [bonnet] Triumph 3
7 MGC MGC hood [bonnet] MG 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
