hood bonnet prop rod
jvandyke
My '63 has a prop rod for the hood, attached to the hood but I'm not sure where it's supposed to be anchored when the hood is up. Up til now I've just put in on the rubber channel strip, but the glue gave way on that the other day, slamming the hood on the prop rod and chipping the paint on the fender in the process. Where is it supposed to go?
Jer
about 6 inches back from the rad saddle under the lip of the left fender should be a metal tab with a slot for the prop rod. I looked for a picture but don't have any showing it on my car - sorry
jlaird
Think he ment when it is up?
jvandyke
jvandyke
Yeah, put simply, when you lift your hood, where do you put the prop rod end?
Brian_C
Member
Check out the photo. This is what I have on my 64, the only difference is it's on the driver's side
. Should be pretty obvious if it's there. If not, then it may have been removed/broken off in the past.
B
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
A Bonnet [hood] prop attachment Triumph 16
P Bonnet Hood Prop Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S Forward opening hood / bonnet Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
anarchy99 Bonnet / hood fit question... Spridgets 2
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
G TR4/4A Random Hood/Bonnet Question Triumph 6
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
JPSmit Separate Thread - A40 Somerset hood [Bonnet] ornament Other British Cars 0
R hood or bonnet whichever you prefer Spridgets 3
HealeyRick Bonnet/Hood adjustment Austin Healey 3
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
T TR2/3/3A Dzus on Bonnet [hood] - Is there a spring? Triumph 4
B Sunken hood/bonnet Spridgets 0
RJS Emergency hood/bonnet release Triumph 22
J Aerocatch style bonnet catch for flip-front hood Spridgets 6
P TR4/4A Need help with TR4A bonnet/hood mount problem, thanks! Triumph 4
T Hood / Bonnet Louvres Austin Healey 6
AH67 Steel Louvered Bonnet/hood for Austin Healey 3000 Austin Healey 1
P Spitfire SPITFIRE HOOD/BONNET LATCHES NEEDED Triumph 3
C Berkeley Hood/Bonnet ornament Restoration & Tools 13
jvandyke hood [bonnet] release broken cable Spridgets 34
O 1960 Healey 3000 BN7 front hood/bonnet Austin Healey 2
G Replacement of Bonnet/Hood Hinges/Gaskets/Hardware Triumph 5
JPSmit Hood [Bonnet] release question Spridgets 1
BobbyD TR6 TR6 Hood/Bonnet Install Triumph 2
M TR4/4A Wanted: TR4 Hood [Bonnet] Triumph 6
W Rattling hood/bonnet MG 4
neilh Hood [ bonnet] alignment - or lack of! Spridgets 12
jjbunn Bonnet/Hood Plunger MG 7
jjbunn Hood/Bonnet props MG 27
S MGA MGA Bonnet [Hood] adjustment. MG 7
bcbennett Hood [bonnet] alignment Triumph 6
cheekygeek MGB MGBs for Dummies: How to open the hood/bonnet MG 9
78Z Added gas struts to hold up hood [bonnet] Triumph 3
7 MGC MGC hood [bonnet] MG 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
