TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6
Serge Decorte
I am restoring my 1974 TR6 and need some help finding how to position the 4 buffer wedges for the bonnet / hood. I have the holes pre-drilled on the top of fender but the buffers are not. Not sure if you need to have it aligned with the top of fender or resting on the base of the bottom lip. Also which side of the wedge is facing the fender.
Pictures displayed on the forum would help, not as a link as they are sometimes difficult to open or require a subscription.
Thanks a lot
poolboy
The flat side, not the sloping side, rest against the fender.
As far as vertical placement, there's not much space available. Just place them as high or as low within that space as need be to be functional...reducing (or eliminating 'ha') side to side movement of the bonnet when closed.
S
Serge Decorte
Ok, thank you for that. There is about 3/8 " distance to spare up or down. I might wait until I am ready to reinstall the hood after the engine is back in place.
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
P Pedal Position Adjustment Austin Healey 2
A TR2/3/3A Seat position Triumph 2
Healey Nut Seat Base Frame Position Austin Healey 4
Jeepster Clutch Pedal Position Austin Healey 4
chicken Inner Door Seal Trim Position Austin Healey 6
B Roof vent position on BN7 hardtop. Austin Healey 15
G Valve adjustment and easiest way set cam position Austin Healey 15
steveg TR6 TDC - Position of rotor and wires Triumph 4
L Seat position for a BN1 Austin Healey 0
Upland 3 position headlight switch is now 2 Spridgets 1
J TR2/3/3A Front apron position Triumph 9
D AH 300O MK1 Choke Knob Position Austin Healey 5
G BJ7 Window channel position Austin Healey 1
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
D TR2/3/3A Dipper switch position Triumph 13
W Cam gear position BJ8 Austin Healey 11
S TR2/3/3A how to position pieces when painting Triumph 7
J MGB 1977 MGB starter activates when key on the "on" position. MG 6
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
S TR4/4A Ignition switch key position Triumph 2
J TR4/4A Horn clip position. Triumph 6
P bumperettes position BT7 Austin Healey 8
K TR2/3/3A Correct position for flasher bracket? Triumph 7
N TR4/4A no spark in start position Triumph 8
gbtr6 TR6 Help! Starter runs with ignition in on position Triumph 18
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
E TR4/4A TR4 Throttle shaft position Triumph 1
R TR2/3/3A Position of LTD fastener on new top Triumph 5
M Accelerator Pedal Position Austin Healey 4
J TR4/4A 175 CD needle position? Triumph 5
TRclassic3 TR2/3/3A SU Upper jet bearing position Triumph 5
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
A TR2/3/3A TR-3A steering wheel position [measurment needed] Triumph 3
Gliderman8 TR6 Starter energizes when in RUN Position...... Triumph 17
vette Seat floor position Austin Healey 10
B Spin on oil filter position Austin Healey 1
P Interior door opening handle position Austin Healey 11
Tinkerman Wheel Knockoff position Triumph 7
T Spitfire Grease slinger position on a Spit 1500 axle Triumph 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
S XKE Accelerator Ppedal Position Jaguar 2
CanberraBJ8 no.1 cylinder position in Distributor? Austin Healey 2
M Wheel and Axle position Spridgets 12
M TR2/3/3A Position/Adjustment of TR3A Clutch Slave Cylinder Triumph 20
richberman Bonnet release handle on BJ8 position Austin Healey 10
R TR5/TR250 Tr4, 4A and 250 gas cap position? Triumph 6
AUSMHLY Does your window rattle when in the down position? Austin Healey 3
chicken Quarter light position to high Austin Healey 2
