steering tight in center position of steering wheel
maxwedge5281
I bought a bn6 about 16 months ago and finally got it on the road. while steering down the highway there is a tight spot to either direction while traveling on the street. otherwise all seems to be okay with the steering. is it practical to back off the locknut on the steering box and adjust the set screw a few degrees to see if this loosens the tightness when steering right or left of center? I did fill the steering box with penrite as it was almost empty.
steveg
I like to loosen the locknut (3/4") and use a coin to lightly tighten the screw till I can just feel it touch then back off a hair. Then tighten the locknut without further tightening the screw. The stock steering is usually tightest at the center, then it loosens to either side.
maxwedge5281
maxwedge5281
thanks steve. i finally got around to the adjustment. I loosened the lock nut and turned the adjustment screw counterclockwise maybe 30 degrees. i tightened the locknut and went for a test drive. amazing difference in the steering feel and the steering effort was totally free in the center position. and, the steering wheel has very little play!
MikeAH100M BN2 Tight Steering Austin Healey 4
B Excessively Tight Steering Austin Healey 19
L Tight spot on steering box is way off Austin Healey 18
M Tight steering. Austin Healey 5
T TR2/3/3A TR3A tight steering/silent blocks Triumph 8
D How tight should the steering wheel nut be? Triumph 20
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
kodpkd Leather Steering Wheel Cover Austin Healey 3
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
S Steering Wheel Brand Austin Healey 5
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
B TR4/4A What is this Steering Wheel Center? Triumph 6
M MGA RHD twin cam steering pinion MG 0
W BN1 Steering Box Removal Austin Healey 11
B Steering Column Wiring/Sealing Austin Healey 1
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering Triumph 4
S TR2/3/3A Steering wheel removal. Triumph 4
W BN1 Steering Box Austin Healey 3
Walter74 Steering Column Felt Bushing Austin Healey 3
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
LAW75 Derrington Steering Wheel Austin Healey 19
Martinld123 Steering Box Leak Austin Healey 27
waltesefalcon New steering wheel Other Cars 2
M T-Series TD/TF Steering Free Play Question MG 6
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
