Hood [bonnet] alignment
bcbennett
Hello all,
The man who rebuilt my engine at the Triumph shop did a superb job, but he works alone. Thus, when he refitted my bonnet, it didn't quite align properly, and the catch won't keep it locked down (and is out of adjustment range).
So, my question is this: I live alone. Is it POSSIBLE for me to adjust my bonnet to a better alignment by myself or must I get a helper? Are there tips and tricks to this?
My brother (who does NOT own British cars) is laughing at me via telephone for not just "going out to my garage and doing it." I can't imagine how I can pull this off alone.
Thanks!
bash
I put my bonnet on a while ago with help, but we didn't have time to get the alignment just right. I then adjusted it on my own by removing the grille (which involves removing the radiator shroud too) - this gives access to the bolts holding the hinges to the inner wings. It is a long process, and I won't pretend that I got it spot on - but it is a lot better than when I got the car, and looks okay from a few feet away, so that will do for now!
Hope that helps
Alistair
G
Ditto on doing it alone. It is just a very slow process, hit and miss, trial and error. Removing the grill will make it easier. Take the lock assembly completely off the bonnet, let the rubber stops seat in the rear (they are also adjustable) and line the thing up by playing with the hinge bolts. Taint easy, but this really isn't a two-person job anyway.
Be carefull and don't rush because you will be touching up paint. I used some towels to help cushion the bonnet hear and there.
Bill
Kurtis
I agree with others. You can align it yourself by loosening the bolts and moving it ever so slightly. It's just a long, tedious trial and error process.
Tomster
[ QUOTE ]
Bill
[/ QUOTE ]
Tomster
Oops well that didn't work.... (quote function)
Should have been:
Either remove the lock assembly or add the emergency release first. No end of misery and trouble if you blow that little maneuver!
neilh Hood [ bonnet] alignment - or lack of! Spridgets 12
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S Forward opening hood / bonnet Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
anarchy99 Bonnet / hood fit question... Spridgets 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
G TR4/4A Random Hood/Bonnet Question Triumph 6
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
JPSmit Separate Thread - A40 Somerset hood [Bonnet] ornament Other British Cars 0
R hood or bonnet whichever you prefer Spridgets 3
HealeyRick Bonnet/Hood adjustment Austin Healey 3
B Stainless hood / bonnet and trunk / bood support rods Austin Healey 2
T TR2/3/3A Dzus on Bonnet [hood] - Is there a spring? Triumph 4
B Sunken hood/bonnet Spridgets 0
RJS TR4/4A Hood/Bonnet Prop Rod Rattle Triumph 10
RJS Emergency hood/bonnet release Triumph 22
J Aerocatch style bonnet catch for flip-front hood Spridgets 6
P TR4/4A Need help with TR4A bonnet/hood mount problem, thanks! Triumph 4
T Hood / Bonnet Louvres Austin Healey 6
AH67 Steel Louvered Bonnet/hood for Austin Healey 3000 Austin Healey 1
P Spitfire SPITFIRE HOOD/BONNET LATCHES NEEDED Triumph 3
A Bonnet [hood] prop attachment Triumph 16
C Berkeley Hood/Bonnet ornament Restoration & Tools 13
jvandyke hood [bonnet] release broken cable Spridgets 34
O 1960 Healey 3000 BN7 front hood/bonnet Austin Healey 2
G Replacement of Bonnet/Hood Hinges/Gaskets/Hardware Triumph 5
P Bonnet Hood Prop Triumph 2
JPSmit Hood [Bonnet] release question Spridgets 1
jvandyke hood bonnet prop rod Spridgets 4
BobbyD TR6 TR6 Hood/Bonnet Install Triumph 2
M TR4/4A Wanted: TR4 Hood [Bonnet] Triumph 6
W Rattling hood/bonnet MG 4
jjbunn Bonnet/Hood Plunger MG 7
jjbunn Hood/Bonnet props MG 27
S MGA MGA Bonnet [Hood] adjustment. MG 7
cheekygeek MGB MGBs for Dummies: How to open the hood/bonnet MG 9
78Z Added gas struts to hold up hood [bonnet] Triumph 3
7 MGC MGC hood [bonnet] MG 2
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
