Help With Side Vent Glass Removal
PeterB
Trying to take apart my side vent windows to send them out to be rechromed. Everything is apart now except for the glass. Anybody have any tips to get it out??? I am trying not to break it....
Keoke
HI see if your plater knows a secret
Healey Nut
Lots of patience , wear a rubber glove to help you grip the glass start at the top and pull up on the frame pulling down on the glass .
Looking at the picture your chrome looks good . To be honest I would polish it and install them . You dont want to bend the frame trying to get the glass out then it will be more expensive for your plater as the metal will need repair as well . Or you may slip and trash the frame and glass .
bob hughes
One of mine will fall out if you look at it, but the other is firmly stuck in. You could try pulling on the rubber if you can get hold of it - this will stretch it and make it thinner and the glass may then be able to be eased out. How about soapy water and a blade to ease it down between rubber and glass? I have not tried any of this myself- but did try putting glass into the main side window frame by stretching the rubber.
:cheers:
pkmh
As one thought, what about first using a penetrant like PB Blaster, to soak the rubber and then slide between the rubber and glass, a safety razor blade to finish separating on both sides. Then if necessary or make easier, pull apart with the use of rubber gloves.
John Turney
A water-soluble cleaner like 409 would be better than something like PB Blaster. PB Blaster may make the rubber swell; not what you want. A safety razor between the glass and rubber may also loosen the grip.
RestoreThemAll
Peter, did you solve this? What worked?
P
PeterB
I tackled and finished the two windows yesterday. They weren’t too bad. I used an X- Acto Knife and Formula 409. I soaked the window glazing in 409 then used a #17 chiseling flat blade to slide between the glass and glazing. With some care and patience I was able to remove the glass without damage.
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
D BJ 8 Side window broken - Help !! Austin Healey 9
I Bugeye side curtain bracket help Spridgets 2
I Help on installing side curtains and rag top on Bugeye please Spridgets 4
B Looking for passenger side rear marker light module-and lots of fixes/help needed pls Spridgets 13
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
