Headlight relays!.....
Gliderman8
......Now I have them!
I ordered the parts (relays, fuse holder, relay recepticles) some months ago. Today was the day I decided to mount the components and wire it all up.
Have four fuses... one for each high-beam and one for each low-beam. Total cost for everything including two spare relays was $27.
Platinum
Four more fuses, two relays... that makes about 22 more places for corrosion to stymie the electron chasin' process when something goes FUBAR. :smirk: :jester:
TomMull
More connections certainly, but the separate circuits will surely make it simpler to locate faults. Nice job Elliot. Tom
dklawson
A little dielectric grease on all the blade contacts will also keep away most of the corrosion.
I added relays like that to the Spitfire and the Mini. I am glad that I did. Nice bright headlights and not much current flowing behind the dash.
dklawson
At the time I installed the relays (in both cars) I also changed to sealed beam halogens from "regular" incandescents. The headlights were definitely a lot brighter but... only part of that brightness would be attributable to the relays.
Gliderman8
Gliderman8
tdskip said:
Did you notice a difference in the lights Elliot?
Nice workmanship.
As a matter of fact, I did notice that the lights were in fact brighter. The main reason I did it was to take the load off of the main switch on the dash. Really, it will be a lot easier to track down any problems (if any) the way it is now, than to have to pull the dash and replace the main switch.
Thanks for your kind words Tom.
DNK
Pretty Elliott, but wrong colored wires?
poolboy
I think it is a good idea to have a relay, for the reasons you cited, Elliot.
What fuse did you use for the low beams ?
Gliderman8
Gliderman8
Ken- I used 10 amp for the low and 15 amp for the high.
Don- It must be your screen... the colors are all correct since that's the wire color I had and it never came with relays so its got to be correct.
TR6BobNF
Elliot:
Would that kit fit a TR6? The headlight relay kit for a TR6 from Advance Autowire is $90USD. Yours at $27.00 sounds good. Where did you get it?
Thanks,
TR6BobNF
Duh!! First day with my new eyes! See you have a TR6 Elliot - where did you get your kit? :0)
Thanks,
Gliderman8
Gliderman8
Thanks,
Bob-
I did NOT buy a kit.... I just bought the components and made my own and that's why it was only $27.
I got my parts from: https://www.delcity.net/
dklawson
EDIT: OOPS, I was typing while Elliot was typing.
I'm not sure he said this was a kit. You can use the schematic on the Advance Auto Wiring web site to lay out your own panel. The relays are available at very reasonable prices on eBay. I think the last ones I bought were a set of (5) 40 Amp relays with pre-wired, locking, matching bases for about $20 delivered.
I have some of those fuse boxes. I bought mine from Waytek (wayteckwire.com). The only drawback to buying from them is they have minimum quantities. They do sell the relays and bases though so if you bought all the parts there you could still get the components (less wire) for under $27.
If you want to "match" the wiring color codes, you can always buy the Lucas color coded wires, bullet connectors, and bullet couplers from Britishwiring.com
trrdster2000
All, VB sells the whole wiring and relay kit for about $30. You will need to get your own fuse box. Autozone sells a good one. Be aware that the plug in will not fit through the opening in the head light bucket, the wires need to be cut and soldier back, no wire connector here. A larger hole with a larger rubber grommet would also work.
I came off the solenoid on the 4A with the fuse box on the inter fender beside the voltage regulator. On a TR6 maybe off the starter motor or if you have easy access to the back of the amp meter, two large plugs there, never did figure why they were put there, as it's very difficult to get at for plugging in something like a radio.
Wayne
TR3driver
Great Pumpkin - R.I.P
If you do that, though, on a car with an ammeter (TR2 through early TR6), the ammeter becomes inaccurate. Basically the current drawn by the headlights will show up as charge, even if the battery is actually being discharged.
IMO, terminal A1 on the control box (for cars with a Lucas generator) is a better choice.
DNK
Del city doesn't do a minimum, but is a little pricier. you just have to do a comparison between them.
Scott_Hower
British Wiring sells everything too. Prob about $30.
Instead of using a separate fusebox, I bought fuseholders that mount to the relay sockets. Makes it a little easier/cleaner to mount.
Dont forget to supersize your headlight grounds; most guys forget to do this.
Spock TR6 '72 Headlight Relays Triumph 4
M Headlight relays Austin Healey 17
4tecdog Headlight relays the easy way Austin Healey 13
B Horn/Headlight Relays Spridgets 13
L BE Headlight Relays- Photos Spridgets 1
B Headlight relays Spridgets 2
G Headlight relays Spridgets 11
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
