HD8s easily rebuilt at home
steveg
My car had been backfiring at low speeds and it turns out the butterfly shaft plastic bushings were worn and the jets were off-center.
This book describes exactly how to hand-roll the new bushings and how to install them and the shafts. That plus new jets, centered with new needles and voila, the carbs are rebuilt.
Car runs much better now. Idles normally and the lift pin works!
The book is also useful in that it describes how the SU carbs work.
4tecdog
Thanks for that tip steve I have just located a used copy of it, look forward to reading it before servicing my frogeye carbs this winter could save a bit of head scratching :encouragement:
steveg
steveg
After being plagued for years with an idle which would start at 1500 then descend to <500 and die, after replacing the plastic bushings, my carbs now idle steadily at 750 rpm with the slow-running screw only. At shutoff, there is less running-on but it's still there. Will follow up on that if I manage to solve it.
What I've learned from the Des Hammill book:
--piston springs need to be the same length and strength - how to measure with kitchen scale.
--if carbs not balanced one set of 3 cylinders is fighting other set.
--float chambers need to contain same amount of fuel - he says dismount carb and empty into measure. I plan on sucking fuel out with measured syringe.
--main jet depression to be set with dial caliper to be the same for both carbs -- he says they're precision instruments and if you can't do that there's a problem elsewhere, such as an air leak.
Moving forward with making wood indicator rods to show position of needles at different speeds as you drive.
Not quite ready to address modifying needles (per Dave Red57) :smile:
PS - carbs running much better since re-bushing. Wonder if HD6s couldn't be bored out to accept the HD8 plastic bushings.
steveg Weber balancer on HD8s Austin Healey 11
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
S Procedure for setting and tuning HD8s? Austin Healey 10
G HD8s Manifold Setup Jaguar 2
Paul Slice TR6 Are SU HD8s to big for a 71 TR6? Triumph 24
P Hoping someone has this measurement easily available. Austin Healey 3
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
JimTR4 TR4/4A Coil - easily confused... Triumph 6
poolboy For Sale REBUILT Carbs for TR6 Triumph Classifieds 0
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
D The best place to get shocks rebuilt. Spridgets 8
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
mrv8q TR2/3/3A Rebuilt or new radiator? Triumph 12
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
K For Sale Two Rebuilt TR3 AUC 878 SU Carbs Triumph Classifieds 3
D Starting After Carbs Rebuilt Austin Healey 30
S TR2/3/3A problem just rebuilt SU carbs Triumph 28
Csarneson Storing a newly rebuilt engine Austin Healey 25
Got_All_4 TR6 Engine pulley dampener 69 vs 70 also new or rebuilt Triumph 1
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
D Need to get a vaccuum advance rebuilt Jaguar 2
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
vickxxx T-Series Distributor rebuilt MG 2
B General TR Putting the rebuilt gear box back in the TR6 Triumph 1
S My recent decision regarding oil in a '66 3000 with a rebuilt engine Austin Healey 101
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
M rebuilt gauges Spridgets 10
gbtr6 General Tech What oil to use in the gearbox, not rebuilt. Triumph 9
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
britlover TR4/4A Where can I get an A-type TR4A Trans rebuilt in SE Michigan? Triumph 9
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
J Starting rebuilt engine ! Austin Healey 8
F TR2/3/3A I just installed a rebuilt C39 Generator on my TR3 Triumph 11
bugedd Front end rebuilt help Spridgets 6
5 How not to start a freshly rebuilt 100/6 engine Austin Healey 30
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
T TR4/4A Breaking in a new rebuilt engine Triumph 7
Sopwith_Camel Rebuilt engine! Spridgets 8
R TR6 TR6 engine rebuilt Triumph 52
TulsaFred Rebuilt 1275 slowly getting dialed in Spridgets 14
TulsaFred First start trouble rebuilt 1275 Spridgets 29
MGTF1250Dave TR2/3/3A TR3 Engine Rebuilt & Installed Triumph 7
M Rebuilt carbs / Idle racing to 3000 Triumph 16
PATR8 First long ride on my rebuilt 8 motor Triumph 3
S old question maybe?, rebuilt engine Triumph 3
