MGB-GT GT brake shoes
Sparky
Member
Does anyone know if the brake shoes for a 74 gt is different than a roadster. I know the wheel cylinders on gt have larger bore. The shoes on it are 1 3/4" wide and the ones I purchased locally are 1 5/8"
Thanks
William
There is definitely a difference between suppliers when it comes to brake shoes. The parts themselves should interchange between GT and ragtop!
-Wm.
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
warwick-steve Brake shoes won't move back after releasing handbrake Austin Healey 8
certifiedcarnut 948 front brake shoes warning Spridgets 5
maxwedge5281 rear brake shoes Austin Healey 11
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
E rear brake shoes Austin Healey 1
I Relining brake shoes Spridgets 19
RickB Source for brake shoes - 78 Midget? Spridgets 8
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
Andrew Mace Revelation about brake shoes Triumph 4
mgbmedic Wedge TR7 Rear Brake Shoes Triumph 7
Dan_Willert Brake shoes rub MG 9
bcbug midget rear brake shoes adjusters Spridgets 4
Hairyone bugeye rear brake shoes Spridgets 5
bigjones Installing rear brake shoes Spridgets 40
JohnnyMead TR2/3/3A TR3a Brake Shoes Triumph 3
jlaird Question-rear brake shoes Spridgets 7
S Brake Shoes Austin Healey 3
DNK Rear Brake Shoes Triumph 14
jdubois Anybody use Porterfield R4-S brake pads/shoes? Triumph 9
healeyboz Brake shoes Spridgets 3
M Car doesn't like my shoes [Brake fluid in cockpit] Spridgets 28
RedTR3 Installing new rear brake shoes Triumph 5
V looking for mg brake shoes MG 1
A TSI--kevlar brake shoes?? Triumph 10
I BN1 Brake Saga Chapter 4 : Wrong size shoes !? Austin Healey 2
J TR2/3/3A TR3 Brake Shoes Triumph 5
R brake shoes Austin Healey 2
Michael Oritt Elva front brake shoes and cylinder kits Other British Cars 67
B Brake shoes dis-bonded Austin Healey 7
F porterfield brake shoes [need cores] Austin Healey 4
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
