Installing new rear brake shoes
RedTR3
I have replaced the rear brake shoes and cylinders. Now the drums are so tight I can hardly get them on. I disconnected the hand brake cables and set the adjuster fully closed and I can still hardly get the drum on. I am afraid it will not turn if I seat it fully on.
The drums are in pretty good shape so I did not have them machined - but I guess turning them would help.
Someone mentioned that there may be an orientation for correct arc on these shoes as to which is toward the front or back and if so how do I identify this?
kodanja
you may have to release the brake fluid pressure, then bleed the system after assembly
hondo402000
I have sanded down brake shoes in the past and once you get them on and running they will wear into the drum
martx-5
Very often, it's just a rust ridge that won't allow the drum to go onto the new shoes. Check the very outside part of the drum and see if you have that ridge there. If so, you should be able to just knock it down with a small grinder or some sandpaper. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
sp53
Yes I had the same problem once. If you take the shoes and drums to a quality brake shop they will arch the shoes to fit the drums.
Sp53
bigjones Installing rear brake shoes Spridgets 40
TR6oldtimer Installing Rear Brake Cylinder Triumph 9
PeterK Installing rear brake drums Triumph 5
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
D Installing a rear bumper guard?????? Triumph 5
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
jlaird Installing the rear main cap cover correctly: Spridgets 3
Wana Installing new rear shocks Austin Healey 8
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
