Installing Rear Brake Cylinder
TR6oldtimer
Buckeye Triumphs once posted an article by Nelson Riedel on how to overhaul the rear brakes of a TR250 and TR6 (I also believe it is the same for as at least the later TR4's). This article is still available on line. For the most part the article is a great reference. However, the article is in error on how to install the rear cylinder locking plates.
The portion of the article in question is displayed in the first attachment.
The second attachment shows the proper way to install the locks. Part A and B are installed first. The tabs on the locks pointing out and up. Once on, insert tab C until the tabs on part A engage.
Note. Be sure to install the emergency brake arm before inserting the locks and grease both sides of the brake backing plate where the cylinder and part A ride on.
TR4
Thanks Ray, I have all the parts to do this project over the upcoming winter. Nice to have a great photo reference along with the instructions.
kindofblue
Do you have a link to the complete article? I have to replace the wheel cylinders on my 4A and would like the correct/best way to install the shoes.
toysrrus
Hi There Kindofblue;
Hey; Have`nt seen you around the Forum lately: What have you been up to?
Regards, Russ
TR6oldtimer
TR6oldtimer
Here is the link. Select the technical button. I'll also link to it on Wiki
Buckeye archive
kindofblue
Thanks
That should help a lot. Hey Russ - the wheels cylinders on the car froze and started leaking. I have a week and a half to Get R Done before VTR. I already orderered new parts from TRF.
kindofblue
/bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif /bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif /bcforum/images/%%GRAEMLIN_URL%%/thankyousign.gif
The internet is a wonderful place. Thanks to the links and information here, I was able to disemble and reassemble the rear shoes and master cylinders without cursing. It took about two hours per side, I would have had no idea how to put it all back together without this information.
All that is left is adjusting the parking brake cables and bleeding.
Andrew Mace
kindofblue said:
...All that is left is adjusting the parking brake cables and bleeding.
Just an FYI, if you are/were having problems with the parking brake, the cables are about the last thing to adjust (unless you absolutely know they've stretched). With properly adjusted rear shoes and properly sliding (and otherwise functioning) wheel cylinders, odds are any parking brake problems you had will have gone away.
T
Tinster
Gosh Andy, if only that were true.
David installed new brake cylinders when he was here working
on Crypty and the brakes and brand new emergency brake worked
just fine.
I messed up and had to install brand new shoes, springs,
pins, clips etc. on both rear wheels. Brakes worked for
maybe 2 hours but now no rear brake function and no
emergency brake function either.
But that's the Crypt Car for you!!
It's always something breaking down.
d
bigjones Installing rear brake shoes Spridgets 40
RedTR3 Installing new rear brake shoes Triumph 5
PeterK Installing rear brake drums Triumph 5
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
D Installing a rear bumper guard?????? Triumph 5
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
jlaird Installing the rear main cap cover correctly: Spridgets 3
Wana Installing new rear shocks Austin Healey 8
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
