Installing a rear bumper guard??????
dperry
I have a rear guard to install on my 72 TR6. Looks like I may have to remove the bumper to install. Anyone have experience with these? Is there a short cut or something I am over looking? The mounting holes are there. Just looks like a bigger job than the 4 bolts.
Suggestions??
dperry
No..... it's the chrome bar that goes across the back. Moss now offers them but I already had this one and got it re-chromed. Just finished with new tail light lenses and looking for some shortcut. It's got to be easier than it appears.
DP
About the only shortcut to mount those bars is use a self tapping sheetmetal screw that is big enough to tighten up in the existing holes. If the mounting holes are real big, try a spring loaded nut. Otherwise you need long and skinny fingers.
Marv
dperry
I was afraid of that. Was wondering if it would be easier if you removed the bumper. Going to put it on a lift and see what gives.
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
bigjones Installing rear brake shoes Spridgets 40
jlaird Installing the rear main cap cover correctly: Spridgets 3
TR6oldtimer Installing Rear Brake Cylinder Triumph 9
RedTR3 Installing new rear brake shoes Triumph 5
Wana Installing new rear shocks Austin Healey 8
PeterK Installing rear brake drums Triumph 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
A TR6 Installing differential and transmission Triumph 10
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
