Brake Shoes
Sopp
Member
Is there a supplier out there that sells brake shoes for a BN1 ? I have new linings and rivets.
I also need a suplier for the small "piston" with the angled end that goes against the rear brake adjuster.
A point in the right direction would be greatly appreciated.
Thanks,
Sopp
Dave Russell
Yoda - R.I.P
You will likely have to get used parts.
Here are a couple of shops that I have gotten used brake shoes & parts from.
Healey Surgeons
1-301-270-8811
British Car Specialists
1-209-948-8767
Other folks may have more suggestions.
Make sure that your installed linings are thin enough to allow getting the drums on. A lot of Healey shoes require a maximum 0.190" lining thickness. Some linings are thicker.
It would be a very good idea to have a brake shop arc/grind the lined shoes to to your exact drums inside diameter/radius. This insures full lining to drum contact without extensive break in. I personally would have the shop install the linings, measure the drum ID, & grind the correct shoe contour.
For the ultimate in drum braking I would send all shoes to Porterfield to have R4S compound linings installed.
Porterfield Enterprises
1767 Placentia
Costa Mesa, CA 92627
1-800-537-6842
https://www.porterfield-brakes.com/porterfieldckshoes.html
Far more effective braking with less pedal pressure than the garden variety linings.
S
Sopp
Member
Dave,
I will check with the suppliers that you listed to see if they have any used shoes. They might even have the adjuster part.
Thanks a bunch.
zblu,
They are the early narrow shoes. Not sure of the bore size, but they would also be the early style. Chassis #220090.
I guess if anyone out in cyberland has the parts I need, I would be happy to buy from an individual as well as a business.
Also, does anyone have a good picture of the brake and clutch pedal pivot assembly for a BN1 ? I think my first bodyman screwed up when he welded the outer support bracket back on. I don't have enough room between bracket and frame to put the brake pedal pivot in. I need to know what a propper assembly look like so that I make the propper changes.
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
DornTRoriginal For Sale 9 Inch Brake shoes from TRF Triumph Classifieds 5
warwick-steve Brake shoes won't move back after releasing handbrake Austin Healey 8
certifiedcarnut 948 front brake shoes warning Spridgets 5
maxwedge5281 rear brake shoes Austin Healey 11
B T-Series MGTD brake shoes. Are there leading and trailing shoes? MG 1
E rear brake shoes Austin Healey 1
I Relining brake shoes Spridgets 19
RickB Source for brake shoes - 78 Midget? Spridgets 8
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
Andrew Mace Revelation about brake shoes Triumph 4
mgbmedic Wedge TR7 Rear Brake Shoes Triumph 7
Dan_Willert Brake shoes rub MG 9
bcbug midget rear brake shoes adjusters Spridgets 4
Hairyone bugeye rear brake shoes Spridgets 5
bigjones Installing rear brake shoes Spridgets 40
JohnnyMead TR2/3/3A TR3a Brake Shoes Triumph 3
jlaird Question-rear brake shoes Spridgets 7
DNK Rear Brake Shoes Triumph 14
jdubois Anybody use Porterfield R4-S brake pads/shoes? Triumph 9
healeyboz Brake shoes Spridgets 3
M Car doesn't like my shoes [Brake fluid in cockpit] Spridgets 28
RedTR3 Installing new rear brake shoes Triumph 5
V looking for mg brake shoes MG 1
A TSI--kevlar brake shoes?? Triumph 10
I BN1 Brake Saga Chapter 4 : Wrong size shoes !? Austin Healey 2
J TR2/3/3A TR3 Brake Shoes Triumph 5
R brake shoes Austin Healey 2
Michael Oritt Elva front brake shoes and cylinder kits Other British Cars 67
B Brake shoes dis-bonded Austin Healey 7
S MGB-GT GT brake shoes MG 3
F porterfield brake shoes [need cores] Austin Healey 4
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
