Elva front brake shoes and cylinder kits
Michael Oritt
I am looking for a spare set of front brake shoe frames for my 1958 Courier--also front wheel cylinder rebuild kits. The brakes are as originally furnished and were designated #219 in the standard brake shoe book but do not seem to be available from the usual sources. They are 9" diameter and 1.5" wide. Supposedly they were also used on Rileys, Hillmans, Sunbeams, etc. etc.
Used shoes will be fine as I plan on having them redone with racing pads.
Deleted member 3577
Are you going back to the original drums rather than the 240Z?
I get my rebuild kits from www.applehydraulics.com
Of course your numbers will be different if your car isn't stock.
Michael Oritt
Michael Oritt
Dave--
Though the backing plates have been drilled/vented, the drums have been replaced with Datsun Alfin's and the shoes have metallic pads the brake shoe frames and the cylinders are as far as I know original. The brakes are 9" x 1.5".
Do you have a spec for the cylinder and kit? I'm now learning from some other VSCCA Courier drivers that the brakes were also used on Triumph Heralds and perhaps I need to go over to the Triumph forum to see if I can develop a source.
Best--Michael
Michael Oritt
Michael Oritt
Dave--
I don't think I directly answered your question--No, I am not going back to the stock drums. The Alfins are the same size--just different material--as the original steel drums. The frames should theoretically be the same as stock.
Andrew Mace
[ QUOTE ]
The brakes are 9" x 1.5"....I'm now learning from some other VSCCA Courier drivers that the brakes were also used on Triumph Heralds and perhaps I need to go over to the Triumph forum to see if I can develop a source.
[/ QUOTE ]In this case, the Triumph forum has come here. /ubbthreads/images/graemlins/wink.gif
Herald front drums are 8 x 1.25" Girling 2 leading shoe, so they won't work. (Rears are 7 x 1.25" Girling leading/trailing shoe.) Maybe they're TR brakes; offhand I don't know how wide TR drums are, but they might be 1.5". Note that some TR front drums are 10".
Hope this helps a bit.
Michael Oritt
Michael Oritt
Andrew--
Thanks for the info but in the meantime I got a call from Pete at Worldwide Auto Parts who ID'd the brakes as being from a TR2/TR10 and is sending me a used set of shoes that he had in stock.
As always, thanks to the great folks on this list for the assistance. I usually habituate the Healey forum but I see that the same level of cameraderie and interest in others as prevails there is in force here as well!
Andrew Mace
[ QUOTE ]
...I got a call from Pete at Worldwide Auto Parts who ID'd the brakes as being from a TR2/TR10 and is sending me a used set of shoes that he had in stock....
[/ QUOTE ]Well, I'm not surprised either that Pete a: was able to ID these and b: come through with parts. TR2 makes sense. (Note that the "TR10" is incorrect; they would've used much smaller 7" brakes.) After my post, I did come across one Girling catalogue reference that gave a part number and a cross-reference to "Triumph"; unfortunately it did NOT give a model.
Michael Oritt
Michael Oritt
[ QUOTE ]
[/ QUOTE ]
Andrew--
Good parts guys such as Pete are simply wonderful. He also gave me the Moss number for the part (BTW it is the TR2 rear brake). I'm not sure that TR10/Standard 10 is incorrect--but it is much easier to go by TR2 parts as they're certainly more commonly known. BTW I had called Roadster Factory a few days back and they were totally useless--they would only attempt to locate a part if I had THEIR part number. Pete, OTOH, knew immediately what I was looking for off of the industry stanard #219.
I'll soon be adressing the rear brakes and understand that they are off a Morris Minor. ID'ing, sourcing and chasing down obscure parts is undoubtedly part of owning an Orphan car.
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
Here is the list I have constructed so far:
Steering rack...............................Morris Minor
Motor mounts..............................Nash Metropolitan
Boot & Bonnet hinges (MkII)........MGY
Tie Rod Ends..............................AH Sprite MkI
Front A Arms..............................TR-10
Rear End....................................Sprite 3.7
Boot & Bonnet locks..................XK 120
Seats (optional)...........................AH 100-4
Front Upright...............................Herald
Rear Axles..................................Morris Minor ???????
Rear Drums/Shoes.......................Riley 1.5 ??????
Front Drums/Shoes......................TR-2(Rear 9") ?????????
Engine & Gearbox........................MGA
Gages.......................................MGA
Striker Plate & Door latch..............????????
Fuel Tank.....................................?????????(But I have an original one not installed)
Fuel tank sending unit...................MGA
Home Made Elva Items:
Wind screen
Shift lever & Knob
Complete Dash
Steering Column
Door Hinges
Prop Shaft
Radiator
Let me know about the TR-2 shoes, I heard somewhere that they are 1/4" too wide, but I don't know if its true ( I have never tried them)
I am still waiting for a reply from Butch Gilbert Re: the drums & shoes
If you know about anything else.....Please feel free to add to/ amend my list.
Deleted member 3577
Found something else:
Suspension Bushings from Energy Suspension "polyurethane half hourglass shock eye 5/8" ID" # 9.8113G
(They are also used on the panhard bar)
Michael Oritt
Michael Oritt
Thanks for the great info. I'll let you know about the brakes--I am using Alfin drums off of a 240Z and they actually have enough width to accomodate another 1/4 if need be.
One point--the seats are definitely not out of a 100, though perhaps someone switched them and they work. The 100 seat frames are constructed from sheet whereas the seats in the Courier are made of tubes.
Deleted member 3577
Perhaps you can help me identify the seats in my Courier at Beaverun this year. I'm told they were an inexpensive alternative to the original ones & offered in kit cars.(they certainly resemble 100-4)
BTW the valve covers are suspected to be HRG Derrington.
(MGA covers are too tall and rub on the underside of the bonnet)
Michael Oritt
Michael Oritt
[ QUOTE ]
Perhaps you can help me identify the seats in my Courier at Beaverun this year.[ QUOTE ]
Dave---
I'm attaching the only photo of the interior that I have in my computer. I'll take some more tomorrow and send them to you directly offlist.
The seats are original as far as I know and are very similar in appearance to MGA seats except that there is one additional pleat on both the seat cushion and the back. They are actually a bit assymetrical, the inside corner of each backrest being a bit higher than the outside, tracing the line of the scuttle.
The seats in 100's are totally different--both in construction and appearance.
Look forward to seeing you at PVGP and also hopefully Beaver Run. BTW I am on the entrants' list for the SVRA Sebring event next month. Pretty excited....
Andrew Mace
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
Andrew--
[/ QUOTE ]I couldn't agree more about Pete. Again, though (see above), the Triumph/Standard 10s used smaller Girling brakes.
The early TR2 (Lockheed) rear shoe reference is correct at 9" x 1.75"; later ones had bigger shoes...and then, ultimately, Girling brakes all around with the changeover to front disc brakes.
It could be that Pete was thinking of the Standard Vanguard range, which I believe used Lockheed brakes throughout; some Vanguards did indeed use a 9" x 1.75" shoe.
I have a pretty thorough Lockheed brake catalogue covering 1948-62 and might be able to help further. Let me know!
Deleted member 3577
I don't have a very good picture of the seats either.....
[image]
[/image]
Michael Oritt
Michael Oritt
Here's a shot of the interior.
Yours are certainly Healey seats--there were slight variations between the 100 seats and later ones and I can't tell which ones you have from the photo.
Michael Oritt
Michael Oritt
Here's another shot.
Deleted member 3577
I went to the VRG/VSCCA, dinner(bench race) last night at the creek house.
It appears that there will be at least 6 Couriers at Beaverun this year.
# 379 Nate Scigliano
# 165 Bill Shaw
# 331 Hervey Parke
# 136 Hunter Lott
# 223 Michael Oritt
# 80 Dave Gills
Michael Oritt
Michael Oritt
There are three signed up to participate at the SVRA events at Sebring in two weeks: Me and George Smith in a yellow car from Birmingham, both with 1600 cc engines and Bob Youngsdahl in a white car from Prior Lake MN w/an 1825 cc engine.
Michael Oritt
Michael Oritt
[/ QUOTE ]I couldn't agree more about Pete. Again, though (see above), the Triumph/Standard 10s used smaller Girling brakes. The early TR2 (Lockheed) rear shoe reference is correct at 9" x 1.75"; later ones had bigger shoes...and then, ultimately, Girling brakes all around with the changeover to front disc brakes.
[/ QUOTE ]
Well, the brake shoes arrived today from WW and--despite promises that they would fit--as Andrew warned they are 1.75" wide. So it's back to the internet...
Nevertheless the pattern of the holes, adjuster notches and radius appears identical with the ones on the Elva and if that is the case I am going to take them to a machine shop and hopefully have 1/8" removed on both sides of the shoe.
My latest good information source identifies the brakes as being identical to those that were used on a Morris 1000. Does anyone have any suggestions as to where I might obtain shoes for that vehicle? Thanks in advance for any leads.
AngliaGT Elva Courier Spotted 0
R Elva Transmission Swap Other Cars 2
Michael Oritt ELVA will be featured marque at VRG's NJMP races Racing 3
Michael Oritt Elva to be featured marque at VRG's 2015 New Jersey Motorsports Park races Racing 1
Elva164 Mike's 1964 Elva Courier MkIV Build Thread! Racing 56
C A very pretty little Elva MkVII Racing 1
elvacar Videos of the Elva Courier Other British Cars 4
elvacar Elva Brochures from the Trojan Museum Other British Cars 0
B looking for Elva courier MK4 Other British Cars 7
B Elva value Other British Cars 2
elvacar Elva She Wins Other British Cars 2
elvacar Elva - She Goes Far Other British Cars 9
elvacar Elva - She Drives Other British Cars 11
elvacar Elva Courier - It lives Other British Cars 11
elvacar Even More Elva Courier Restoration Pictures Other British Cars 7
elvacar Elva Restoration Other British Cars 10
bugimike Nice Elva on ebay! Other British Cars 11
D Interesting E-Bay Elva Formula Jr. Racing 6
Michael Oritt Differential for Sprite/Elva Spridgets 32
curtis Elva info needed Racing 0
curtis Elva Other British Cars 7
Michael Oritt Elva Courier on Ebay Other British Cars 6
Michael Oritt NEED ELVA WHEELS Other British Cars 9
Michael Oritt MGA Elva [MGA 1600] high-speed miss MG 6
Michael Oritt Elva Courier engine number--assistance MG 9
aeronca65t New ELVA Other Cars 7
Sherlock Elva Courier up for grabs Other British Cars 1
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
