Gas cap gasket?
T
Tinster
A quickie question-
I am re-installing Crypty's refurbished fuel tank.
I notice my car has no gasket protecting the car body
from the metal gas cap underside.
Should there be a gasket between the two surfaces to
protect the paint finish from scratches?
thanks,
d
TR6oldtimer
There is a grommet that seals the cap and the body opening. What is that blue stuff?
T
Tinster
Ray=that blue stuff is the blue/gray metal
the gas cap sleeve is made from. Oxidized
light blue for some reason.
Tom- thanks for the reference.
DPO Pedro sure did short change this poor old beast
of car.
d
TR6oldtimer
Blue, never seen it before. My 6 and 250 gas caps are just plain old aluminum gray. At least we now know why the gas tank is painted blue.
/bcforum/images/%%GRAEMLIN_URL%%/smile.gif
tdskip
Dale - how is the gasket where the tank meets the filler neck? I ask since when I pulled my tank I didn't replace that gasket - which was a dumb decision - and the tank leaks now when it is more than 3/4 full...
T
Tinster
TD-
There is a rubber sleeve approximately
3" in length that both the tank filler
neck and the gas cap bottom tube slide
into.
Two clamping bands hold the rubber sleeve
tight .
Here is a 60 mil thickness TPO gasket I
made to go between the gas cap and car body.
It seems to fit pretty well. I could not see
much detail from the Moss diagram. So, my best
approximation.
d
TR6oldtimer
Dale, looks pretty good. The original was a grommet. Attached are pictures of the original out of my '73.
T
Tinster
Thanks Ray!
Why on earth would that moron DPO Pedro have
removed the grommet and not put it back?
Mine is not a grommet but it IS pretty snug tight
and will protect the car paint.
thanks for the photo.
d
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Why on earth would that moron DPO Pedro have
[/QUOTE]
Based on the way that you asked the question, I believe that you have answered it as well.
Brosky
Dale,
What condition is the round rubber seal that goes between the cap ad the top of the neck? This is the one that seals the tank when you close the cap?
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
F Gas cap gasket Triumph 1
L TR4/4A 4A gas cap gasket Triumph 0
L TR4/4A Gas cap Gasket 4A Triumph 2
L Gas Cap Recommendation Austin Healey 1
P MGB Mgb gas tank cap MG 7
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
S TR2/3/3A TR3 gas filler cap Triumph 1
T TR2/3/3A TR3A Gas Cap Triumph 15
K For Sale TR3 Gas Cap Assembly Triumph Classifieds 0
Michael Oritt Gas cap parts now in tank Austin Healey 17
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
K TR2/3/3A Gas Cap Seal Replacement Hack Triumph 0
C TR6 Gas cap venting. Triumph 2
PatGalvin TR2/3/3A TR3A Gas Cap Info and uel tank venting Triumph 4
tahoe healey flip top gas cap Austin Healey 5
6TTR3A TR6 Magnetic ring in the early gas cap Triumph 2
maxwedge5281 gas filler and cap options Austin Healey 9
K TR2/3/3A 3A Gas Cap keeps popping open? Triumph 5
mrv8q TR2/3/3A Gas Cap Q Triumph 4
M TR2/3/3A TR3A gas cap fiber washer Triumph 6
D flip top gas cap?? Spridgets 10
T TR2/3/3A TR3B gas cap Triumph 0
M_Pied_Lourd Wedge TR8 Gas Cap Triumph 35
BillD Gas Cap does fit on new tank's filler tube Spridgets 5
D Gas Cap Spridgets 1
A Gas cap fiber washer Triumph 6
M TR2/3/3A TR3 gas cap question Triumph 4
R TR5/TR250 Tr4, 4A and 250 gas cap position? Triumph 6
T Spitfire A different Spitfire gas cap question Triumph 3
A Gas filler cap Triumph 3
64Elan Source for gas cap Sunbeam (Rootes) 4
64Elan Spitfire Spitfire gas cap question Triumph 10
I TR6 What glue for TR6 magnet in gas cap? Triumph 9
S TR2/3/3A late tr3 gas cap? Triumph 5
S TR2/3/3A Tr3 gas cap vent Triumph 0
Morris Anybody have a gas cap for sale? Spridgets 5
davidb AH3000 - gas cap Austin Healey 3
A TR2/3/3A TR-3A Gas filler cap Triumph 2
V Locking gas cap for 1970+ Midget??? Spridgets 14
JohnnyMead Gas Cap Seal Triumph 13
B Need vented gas cap? Austin Healey 9
I TR6 TR6 gas cap help Triumph 2
G TR2/3/3A TR3A Gas cap help Triumph 14
T gas filler cap Triumph 12
kyreb1862 Locking Gas Cap MG 12
angelfj1 TR2/3/3A TR-3A - Locking Gas Cap??? Triumph 15
DNK Wedge TR8 Gas Cap Triumph 2
J Vent gas cap or not Spridgets 12
PATR8 Wedge TR7/8 small gas cap Triumph 29
