Vent gas cap or not
jbuffalo
1978 Mg Midget, Weber carb , no smog equipment, electric fuel pump, weber and fuel pump are new. The car seems to be starving for gas, I went about 1 mile and it stalled, waited 30 seconds and it started up. Do I need to vent the gas cap-it is not vented? Just took off cap and it runs real well-I think? thanks Jim
tosoutherncars
Excellent question, I eagerly await the answer! Although my "sealed" gas cap couldn't seal much these days, the seal has completely disintegrated...
Jim, is it a HVLP pump? (approx. 4 PSI, but high volume?)
jlaird
Try this, a peice of plastic wrap or alum foil over the tank cap inlet with a rubber band around it. Poke a small hole in the plastic or alum. Give it a go. If it solves the problem you know the cause.
Now me I would just take the cap off and drive it around some.
spritenut
If the cap is old, they get condensation inside the vent and rust closed. A quick cure is to slice a Vee out of the rubber seal. If you hear a rush of air when you remove the cap, the vent is clogged.
I am not sure about the 1500s but all other Spridgets used a vented cap.
You might have a float adjustment problem on the Weber too.
JPSmit
some of the decision will depend on the gas tank itself. Smog equipped cars have gas tanks with a vent hole that vents through the vent/filter mounted inside the trunk next to the passenger rear fender. (It's the piece that looks like a large tuna can - sort of) this is then hooked up back to the engine somehow (I have no plans to reinstall so I haven't learned where). Anyway, if like me, you buy a new tank, there is no vent hole for a vent line, thus the need for a cap with a hole in it. I know some have had the fitting for the vent sweated in but I have no plans to.
Hope this helps
R
RonMacPherson
That pressure is too high for a Weber. Just a matter of time before it overpowers the needle and seat. Wanna get one with under 2 psi.
jlaird
So, did removeing the cap fix the problem?
J
jbuffalo
Its great to see a person with focus. No, I did not try a drive with out the cap-I did find that the vent hose from the fuel tank was broken-I fixed it-work is getting in the way of my hobby. Now I am going to look at the cannisters and all the hoses. Found and replaced the brake switch-have lights.thanks Jim
J
jbuffalo
Cap is vented and all vent hoses are off. Car runs great. Check classified for fuel pump block off plates for 1500-cheap. thanks Jim
sparkydave
Do be aware of the vent hose in the trunk; I had mine break and it started leaking gas into the trunk after a fill up. I hope you didn't remove the vent hose completely; you don't really need gas fumes permeating the trunk. The only thing I might mention is I had a similar problem to yours which ended up being the fuel pump having a small air leak that would eventually make the engine start stalling.
tosoutherncars
RE: the fuel pump. webercarbs.com suggests the use of a Carter "green" electric fuel pump, which is similar to earlier Sprite fuel pumps in that it should be set up as a "pusher" low down, close to the gas tank. I'll find a part number. I can't comment on it personally, I'm still using the stock mech fuel pump, with a regulator.
Edit - P/N is Carter 4070
S TR2/3/3A Tr3 gas cap vent Triumph 0
T TR2/3/3A TR3 gas tank vent Triumph 12
S TR2/3/3A tr3 gas tank vent Triumph 3
kyreb1862 MGB 77MGB gas tank vent MG 10
KVH Gas Tank Vent Tube/Hose--Necessary? Triumph 8
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
Bayless How to repair broken vent window studs? Spridgets 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
A PLATE, handle locking on Vent Window Austin Healey 0
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
S TR2/3/3A vent lid rubber Triumph 11
P Rivets on windshield and vent window frame. Austin Healey 1
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
B BJ8 vent window collar fused on Austin Healey 7
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
T TR2/3/3A Rear Axle Vent Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
K TR3A Air vent under grille on Race Cars? Racing 5
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
J BJ8 Float bowl vent pipes Austin Healey 11
Geo Hahn TR2/3/3A Vent Lid Link Triumph 3
M TR2/3/3A Air Vent Drain Hose Triumph 5
P TR6 Air vent hose clamp Triumph 0
S Question: Works Vent, how to fit Austin Healey 0
P Rocker Cover Vent Spridgets 22
D footwell vent Jaguar 3
T Bugeye Sprite defrost vent installation question Spridgets 18
D TR2/3/3A Demisterr vent routing Triumph 6
O TR2/3/3A Fuel tank vent Triumph 1
