Locking gas cap for 1970+ Midget???
V
vagt6
I'm looking for a locking gas cap to replace my broken original. Both Moss and Vicky Brit's locking-type caps are only for "through 1969" Sprites and Midgets. Neither vendor sells locking gas caps for 1970-on Spridgets, excepting the "Aston" quick-release caps, which are a bit pricey ($157 +) for me.
I'm assuming the OD of the gas filler neck is different on the 1970-on cars???
So, who sells a locking gas cap for a '74 Midget?
Thanks, guys.
I think they are the same except the 1970+ are not vented.
V
vagt6
Thanks, Trevor. But, will the pre-70 caps fit a '74? I'm wondering if the hardware on the end of the neck is the same.
Wait until someone else confirms, but I'm 95% sure they are the same.
I also seem to remember that old ford truck gas caps fit. Early 60's I think.
spritenut
Venting issues aside, there were 2 gas caps. The early ones were of the inside clip type, the clips went inside the filler pipe.
Somewhere along the line they went to an outside the filler pipe cap.
Easy enough to tell which one you have just by looking.
And it is also easy enough to swap out the filler tubes from any square body tank.
They also did change the rubber filler hose in later years, longer hose, shorter pipe vs longer pipe and a short elbow hose but all are interchangable.
Well... I stand corrected. This forum works well. :smile:
V
vagt6
Hmmm, Trevor, a <span style="font-style: italic">Ford</span> gas cap on an MG??? :crazyeyes: I'd feel like a traitor, or something, if I used that Ford cap! :yesnod: Thanks for the suggestion, tho'.
If anyone finds the appropriate cap for a post-70 Spridget, please let me know.
There is always the Moss option 202-780, but it would still be almost $100 from a Moss distributor.
spritenut
Pep Boys has the chrome gas caps that fit our cars, $7-$8 bucks off the rack.
Do watch for the depth of the clips, they have one that does not fit, the clips are too far down the cap.There is no listing for our cars but bring in your old and match it up.
I think 66 Ford pick up fits. Or any Ford that had the chrome cap on the side behind the cab.
G
should be up to '72
kyreb1862 Locking Gas Cap MG 12
angelfj1 TR2/3/3A TR-3A - Locking Gas Cap??? Triumph 15
G MGB LOCKING GAS CAP FOR A 1973 MGB MG 9
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
Martinld123 My left rear wheel is locking up Austin Healey 16
A PLATE, handle locking on Vent Window Austin Healey 0
B TR4/4A Self locking bolts question Triumph 13
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
croz TR2/3/3A Heater tap locking nut Triumph 8
R Freeing wheel cylinder locking plate Austin Healey 7
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
D Early 100-Six Locking Door Handle Austin Healey 33
T datsun 5 speed locking up - circlip problems?? Spridgets 0
J TR2/3/3A Rear brakes are not locking up hard enough. Triumph 11
Born_Loser TR2/3/3A Breaks Locking up after a short drive Triumph 15
I bugeye locking trunk panel Spridgets 31
S How to fix Vapor locking from happening Triumph 42
CJD TR2/3/3A TR3 Locking Pawl Triumph 6
H Hardtop locking strip Austin Healey 4
E 1990 XJ-S V12 Front Brake Locking Jaguar 5
G X300 central locking , longish Jaguar 4
tahoe healey locking washers Austin Healey 13
GT6_Mark Remote/Central Door Locking Triumph 7
J TR4/4A TR4 Shifter locking out Triumph 11
Johnny Have TR's ever had locking steering column's? Triumph 21
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
Johnny Locking Steering Column models Austin Healey 4
D facelift xjs central locking............... Jaguar 0
H Brakes Locking Up Austin Healey 16
G Locking nuts, stud insertion and other dilemmas Triumph 11
S Starter is locking-up engine Triumph 9
sparkydave Vapor locking troubles Spridgets 1
8 MGB Locking Fuel cap for MGB MG 8
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
