Locking Gas Cap
kyreb1862
I have had the gas in my 77 B siphoned 3 or 4 times now. Outside of staying up all night, and shooting at someone, can anyone give me a source for a locking gas cap that will fit a 77 B?
Regards John
G
I just tried autozone.com and they have one for 18.99. I remembered getting one years ago for my '72 and I thought it was a local auto zone. You might try your local one first. Or put your zip code in on their web site. Go there and put "locking gas cap" in their search and go through the car model etc and then put your zip code.
Bob
kyreb1862
kyreb1862
I tried Autozone today. They have one listed but I was told the warehose is currently out of stock. I think I'll try back around Friday and see if they have gotten any more in.
Regards John
RickB
What about Moss or VB?
Stewart
With a locking cap all they will do is drill a hole in the bottom of your tank. I know they exist for the 75's as I do have one but I haven't seen a replacement offered new anywhere.
You could always get some fine mesh chicken wire and place it over the opening to the tank and then use the filler neck to hold it in place. It will keep the siphoners in check.
If your positive your getting hit by gas thieves move the filler cap into the trunk and route the outside cap into 2 gallon gas can filled with raw sewage or water or diesel or other other than gas fluid. Bonus points if you can rig it to flame thrower.
Platinum
Reminds me: I gotta beef up perimeter sensors... :devilgrin:
The Triumph folks (particularly the TR-6 lads) have a nifty filler cap. Hinged. Lotus used 'em, too. I believe they had the locking version available and it was originally designed & used on Norton bikes. Tony would have a better idea on the history, methinks. I got a locking one decades ago for the +2.
I would think that'd be adaptable to the B filler somehow.
Steve_S
From a Volvo. You may ahve to install a Mark I filler neck to fit it though.
G
It would be nice if Moss or Victoria had them for a '77 but they don't
V Locking gas cap for 1970+ Midget??? Spridgets 14
angelfj1 TR2/3/3A TR-3A - Locking Gas Cap??? Triumph 15
G MGB LOCKING GAS CAP FOR A 1973 MGB MG 9
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
Martinld123 My left rear wheel is locking up Austin Healey 16
A PLATE, handle locking on Vent Window Austin Healey 0
B TR4/4A Self locking bolts question Triumph 13
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
croz TR2/3/3A Heater tap locking nut Triumph 8
R Freeing wheel cylinder locking plate Austin Healey 7
R Source for return spring on Early BN4 locking door handle? Austin Healey 1
D Early 100-Six Locking Door Handle Austin Healey 33
T datsun 5 speed locking up - circlip problems?? Spridgets 0
J TR2/3/3A Rear brakes are not locking up hard enough. Triumph 11
Born_Loser TR2/3/3A Breaks Locking up after a short drive Triumph 15
I bugeye locking trunk panel Spridgets 31
S How to fix Vapor locking from happening Triumph 42
CJD TR2/3/3A TR3 Locking Pawl Triumph 6
H Hardtop locking strip Austin Healey 4
E 1990 XJ-S V12 Front Brake Locking Jaguar 5
G X300 central locking , longish Jaguar 4
tahoe healey locking washers Austin Healey 13
GT6_Mark Remote/Central Door Locking Triumph 7
J TR4/4A TR4 Shifter locking out Triumph 11
Johnny Have TR's ever had locking steering column's? Triumph 21
Tinkerman TR2/3/3A Locking screw on rocker arm shaft, TR-3 Triumph 4
Johnny Locking Steering Column models Austin Healey 4
D facelift xjs central locking............... Jaguar 0
H Brakes Locking Up Austin Healey 16
G Locking nuts, stud insertion and other dilemmas Triumph 11
S Starter is locking-up engine Triumph 9
sparkydave Vapor locking troubles Spridgets 1
8 MGB Locking Fuel cap for MGB MG 8
Celtic 77 MGB LeMans Gas filler MG 10
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
