Need vented gas cap?
BabaKahawa
My healey came with a non vented fuel cap also.
I reworked the thin metal pressure wings behind the rubber gasket so the cap still closed properly, but was loose enough to vent the tank. It worked and the cap has not come off or makes noise.
I have also heard others who drilled a small hole through the cap to vent the tank.
Good luck.
DerekJ
Absolutely. I had a non-vented replacement cap before I understood the system. On a long road trip the fuel pump would eventually act like it was sucking air. Every 100 miles or so I would stop and tighten everything but, coincidently I always stopped at service stations, at which time also I took the opportunity to top up with petrol.
The refuelling allowed air back into the sytem and off I went blindly thinking that my frantic tightening had done the trick!
BTW that cap was purchased from a supplier of AH parts. They should know better than to sell these things.
bob hughes
My cap is original - no vents and I don't have any problems.
Probably due then to the rubber connection between tank and filler tube as the tank has been replaced at some time with a aluminium one (No pin holes I hope)and when I fill her up there is a strong smell of petrol ( gas) in the boot - ( trunk) for a while.
Bob
B
Bock62
Member
Thanks for all the help! -- When I fill the tank is also strong smell of petrol in the boot for a while.
Since have had no other issues, will assume was 'chasing a ghost" and leave it as is...
I've seen a lot of cars that seep gasoline around the sending unit when freshly filled. Look for stains...
Besides the gasket, there's supposed to be copper sealing washers under the six (6) mounting screws.
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
