Gas filler cap
Arrow
I have 3 TR-3s. I am working on a 60 (produced in 59). Gas tank filler was the type with a nut inside the body. I have a new (Moss) that does not have the nut. If I use the style without the big nut inside what holds it in place? If I use the style with the big nut (which I am leaning towards since that is what the car had) does it get a rubber washer/gasket between the filler cap and the body? Does it also get a gasket between the nut and the inside of the body panel? I took it apart years ago, took great noted except apparently on this piece. My daughter got sick and this has lingered for a few years but I am back at it. Appreciate any insight. Tom
TR3driver
Great Pumpkin - R.I.P
Not much, just being clamped to the hose (which is clamped to the tank) and the grommet that goes in the hole.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] If I use the style with the big nut (which I am leaning towards since that is what the car had) does it get a rubber washer/gasket between the filler cap and the body? Does it also get a gasket between the nut and the inside of the body panel?[/QUOTE]My recollection is that there is a chromed flat washer that goes above the deck, and a fiber or cork gasket that goes under the deck.
A
Arrow
Thanks-I have spent the day working on the tank, stripped to bare metal and now primed. I just found the old filler cap and there is a fiber washer and yes a chrome ring. Chrone ring directly against the paint? Fiber washer below panel between boot and cockpit? NO washer or anything under chrome ring?
Geo Hahn
Looking at mine (early style) it appears I used gaskets both below and above the chrome ring. I probably I made them myself from thick gray/black gasket material. The lower ring has a larger O.D. to match the bottom of the ring.
No idea what would be considered 'correct' but this arrangment snugs up nicely w/o scratching anything.
S TR2/3/3A TR3 gas filler cap Triumph 1
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
maxwedge5281 gas filler and cap options Austin Healey 9
BillD Gas Cap does fit on new tank's filler tube Spridgets 5
A TR2/3/3A TR-3A Gas filler cap Triumph 2
T gas filler cap Triumph 12
Celtic 77 MGB LeMans Gas filler MG 10
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
maxwedge5281 gas filler opening replacement Austin Healey 4
tahoe healey Gas filler tube gasket Austin Healey 11
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
JPSmit Gas filler pipe question Spridgets 1
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
