gas filler cap
T
Tinster
I know a bunch of folks have rechromed their bumpers and
vavle covers.
Has any one ever rechomed their gas caps, or lug nuts
or door handles?? In the ballpark- what's it cost?
thanks
dale
Gliderman8
I am just about done with a full frame-off resto. About two years ago I did rechrome my gas cap. It came out great. I did it since it is a focal part of the car. I just couldn't put the pitted one back on with a fresh paint job. Cost two years ago was about $75. Today I know it will be lots more. It's also easier to do when the car is apart since getting the cap out requires some work in the trunk to remove the panels, etc.
The door handles I just took to a polish wheel and they came out OK... not great, but acceptable. Bumpers were also rechromed.
DNK
Dale- Two Thoughts:
1. Do you have somebody on the island that does that?
2. If you do it is probably cheap as PR can't have the same EPA problems the continent does.
Tinkerman
Dale, big problem is that those caps are pot metal and expensive to replate. At least around here. I was quoted $200 so I bought a new one from TRF. If the stuff is brass, generally $30 to $50. Lug nuts would be cheaper. Again thats the Knoxville, TN area.
Cheers, Tinkerman
angelfj1
Don: The EPA requirements are more onerous on PR than the 48. Generally speaking, toxic materials are shipped off island for disposal which is very expensive.
T
Tinster
DNK said:
Dale- Two Thoughts:
Don- we have MUCH higher EPA standards because of our coral reefs,
huge estuaries and wetlands everywhere along the coast.
No one chromes that I am aware.
PS: PR is is an island --NOTHING is cheap here.
d
roofman
Keep watching ebay Dale, these items in great condition come up from time to time.
DNK
That why I stated my #'s.
If 1 then 2.
If not one because of 2.
DougF
Door handles and lug nuts are probably best to replace with new. Door handles are inexpensive and tend to crack over time at the mounting point.
Lug nuts disfigure and fatigue over time. Plus you would have to contend with chrome bunging up the threads.
T
Tinster
angelfj said:
Dale: Glad your back. I believe that good quality repro gas caps are available. have you checked?
fuel cap
<span style="color: #990000">Ain't back Frank. Just tying up a few loose ends before the move
over to Leadville,CO and the Faro tables. Probably take me a week to sort things out.
My cap is an original and starting to pit.
Howdy to Pat</span>
Platinum
Nobody has said: "Norton motorcycle tank" yet. :smirk:
S TR2/3/3A TR3 gas filler cap Triumph 1
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
maxwedge5281 gas filler and cap options Austin Healey 9
BillD Gas Cap does fit on new tank's filler tube Spridgets 5
A Gas filler cap Triumph 3
A TR2/3/3A TR-3A Gas filler cap Triumph 2
Celtic 77 MGB LeMans Gas filler MG 10
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
maxwedge5281 gas filler opening replacement Austin Healey 4
tahoe healey Gas filler tube gasket Austin Healey 11
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
JPSmit Gas filler pipe question Spridgets 1
mctriumph General TR NEVER start a car with stale gas Triumph 0
TomMull GT6 Gas Tank Outlet Triumph 0
B TR6 Gas on spark plugs Triumph 7
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
edkap2002 TR6 gas tank sounds Triumph 8
MGTF1250Dave T-Series TF Gas Tank MG 6
B General MG 77 MIDGET Gas tank sending unit MG 1
G Wanted gas tank dip stick for mgtf 1555 MG Classifieds 1
Celtic 77 MGB Pessimistic Gas gague MG 10
B gas leak underneath the carburetor Restoration & Tools 2
T TR2/3/3A TR3 Gas Tank Grounding Triumph 9
P MGB Mgb gas tank cap MG 7
LAW75 Concours: Original Gas Hose Austin Healey 12
LAW75 Gas Odor Elimination Austin Healey 3
B TR4/4A GAS TANK FELT Triumph 14
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
edkap2002 TR6 gas smell Triumph 8
R TR2/3/3A Gas pedal pad for TR-2 Triumph 3
B Damaged threads in the gas tank Austin Healey 7
BierRunner TR6 TR6 Gas Pedal Triumph 4
Jim_Stevens Off Topic Ethanol-free gas link Triumph 1
J TR2/3/3A TR3 gas tank mystery Triumph 5
Rob Glasgow New Gas Tank Austin Healey 8
T For Sale TR2 - TR3 Gas Cap for sale Triumph Classifieds 1
B TR4/4A Gas Tank color? Triumph 4
B BE vs. Later Model Gas tanks Spridgets 2
B How to clean the old gunk out of a Spridget gas tank? Spridgets 21
JPSmit Fuel line - gas tank question Restoration & Tools 5
Ripper01 SOLD-TR6 Gas Tank Triumph Classifieds 3
A Wanted Gas tank for TR6 Triumph Classifieds 5
J For Sale Triumph Tr 2/3 Gas Pedal Triumph Classifieds 1
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
D What's inside the gas tank?? Spridgets 13
C TR2/3/3A Gas Line Triumph 11
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
J TR2/3/3A TR3A gas tank repair Triumph 7
longbridgehealey Fuel pump racing, no gas Austin Healey 26
Rut MGB Running out of gas symptoms MG 21
