TR2/3/3A fuel sender
TFB
My fuel sender reads 4.5 ohms ,empty,at the sender regardless of float position.Are these units serviceable?Who has the best replacement sender units post 60k tank?Thanks Tom
TR3driver
Great Pumpkin - R.I.P
I would be giving the hairy eyeball to the connections on the top. The sender might possibly have shorted internally, but it seems very unlikely. Inside, it is basically a wire-wound resistor, and a lever attached to the float arm shorts out part of the resistor.
But the terminal on the top (at least on earlier units) is just a screw through a hole with a phenolic or nylon "top hat" bushing to keep it from contacting the sides of the hole. If the bushing were broken or absent, the screw or nut could be shorting to the mounting plate.
If that isn't it, there is at least some chance you could open it up, find and fix the problem. It is a very simple device.
Sorry, no recommendation for a replacement. I've never had to replace one.
TexasKnucklehead
I assume you removed the wire to the gage, or better, from the sender, before you did your tests? Perhaps you have a shorted wire or gage.
T
TFB
Thanks for all the replies.First test in tank was with wires to sender disconnected.I removed sender and it tested 4-81 ohms out of the car.Looking at the terminals one stud is larger so I thought this must be for a reason so I switchited wires to have 12v from gauge on small stud,with the phenolic washer and it all works now.So either for some reason the sender is polarity sensitive or I got lucky. Thanks Tom
martx-5
If you do need a replacement fuel sending unit, be wary of what's out there. I bought a unit from Moss awile back that fit the tank OK, but gave bogus readings because the design was not right. I bought one from a guy on ebay whose sender more closely matched the original, but had it's little problems also, however, they are easily rectified making the ebay sender useful.
I have it documented in the thread linked to below along with a pic of the three senders...the original, the Moss unit and the one from ebay.
https://www.britishcarforum.com/bcf...-Sender-From-Moss&highlight=fuel+gauge+sender
Edit: I see you got it sorted out while I was typing, but for anyone needing a replacement sender, be careful of what's out there.
Jerry
Bought mine from Rimmer Brothers and it is the most accurate sender/gauge I have ever had in a British Car . Must have got lucky.
Jerry
TR3A
6TTR3A
I've had good luck with the NOS units, although they do vary a few ohms from unit to unit. Some 3-98 ohms, others 5-95 ohms. I don't consider that a big deal since the Smiths design is far from perfect to begin with. I think it is best to calibrate your sending unit with your gauge on the bench to get the best reading. There is probably someone in your club or in your are that can help you if you need.
Frank
dklawson
Calibration of the gauges used before the voltage stabilizer was added is well described on Barney Gaylord's MGA Guru web site. The system is the same.
Start at the link below to get a general understanding, then read forward several pages as he goes over calibrating both with resistors and with your sending unit.
https://mgaguru.com/mgtech/electric/fg_01.htm
TR3driver
But don't forget that the resistances are not quite the same. You need to adjust Barney's numbers to match the TR sender.
dklawson
Agreed. I prefer to calibrate a gauge to the sending unit it will be used with rather than match it to fixed resistance values.
FlyingCat Spitfire Fuel Sender Unit Triumph 2
JPSmit Fuel tank sender - how does it work? Spridgets 4
Healey Nut Fuel Sender Austin Healey 3
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
J Fuel sender, fuel gauge 100 4 Austin Healey 6
sim fuel tank sender reading full all the time Spridgets 9
R Fuel sender internal wire Austin Healey 13
H TR2/3/3A Fuel sender or gauge? Triumph 8
L Fuel Tank sender 100/6 Austin Healey 8
S fuel sender Austin Healey 7
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
J Orientation of sender in fuel tank Spridgets 2
T Fuel Gauge & Sender Unit Austin Healey 5
I Fuel sender unit testing Triumph 2
Jeepster New fuel sender unit Austin Healey 9
J Busted Fuel Tank Sender Unit Screws Austin Healey 7
M Fuel sender unit float leaks Triumph 8
G MGB Fuel sender '71 MGB MG 9
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
pjsmetana Fuel Level Sender needed... Triumph 5
T How best to test a fuel sender off the car? Triumph 10
M Fuel Tank Sender? Triumph 2
Morris Fuel tank sender Spridgets 3
newmexTR3 fuel gauge/sender wiring Triumph 7
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
healeynut Ebay Fuel Tank Sender Austin Healey 5
jhorton3 Fuel Gauge Sender Spridgets 4
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
A Fuel tank sender - direction to install? Austin Healey 3
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
L Fuel sender specs... inaccurate gauge?? Spridgets 4
B Fuel Tank Sender Austin Healey 7
TypeRboy Fuel guage sender for Elans Lotus 0
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
