Fuel Level Sender needed...
pjsmetana
I've been looking on all the sites I can think of, and I haven't been able to find a New or refurbished Fuel Level Sender Unit for my 80 Spit. I can't just rebuild mine because its been Frankensteined with parts from a Sunpro "Universal" unit. My abomination sender unit keeps hitting parts of the tank or coming loose, or any number of ghastly issues, so I really just want to get a new OEM one. But Where??
Thanks in advance guys!
pjsmetana
pjsmetana
Thanks Andy! I guess I forgot to look at BPNW. $36.74 + shipping ain't too bad. Moss, Vicky, TRF, Rimmer, etc, don't have this item. Guess this is another +1 for BPNW.
hondo402000
I just received mine from them yesterday, hooked it up and tested it for empty and full, I did have to adjust the stops just a little but works fine mine was for my TR6 but I assume they are all the same
Hondo
pjsmetana
pjsmetana
The sender arrived today and I just got done adjusting and installing it. Easy as pie. It actually now reads more accurate to that Sunpro Gauge than the Sunpro Fuel Level sender did! :smile:
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
T TR4/4A adjust fuel level Triumph 8
mountainman Fuel Level SU Carbs Triumph 15
boxofparts MGB 79 MGB Fuel Level Sending Unit MG 6
VelodromeRacer Fuel cell fuel level... Racing 12
C Fuel Level Sending Unit MG 4
jerrybny Fuel Filter Level Triumph 8
B Fuel Level In Jet -Question- MG 12
C Front Carb Fuel Level Too High, Rear Too Low Triumph 8
bighly Fuel level sending unit leak Austin Healey 1
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
