Fuel sender unit float leaks
mallard
The fuel guage was not working on the TR6 because the float on the end of the arm was full of fuel. The unit tested good thru out it's range. I have a new unit but it's at least 20 years old so I wanted to use the original. It seems that the originals are better than the replacements. My question is does any of the vendors sell just a new float, or does somebody sell one that is better than the plastic originals? I looked at Moss and TRF and they don't sell just the float. My new 20 year old unit has a new float on it but I'm afraid it may leak in a short time because of it's age. Any ideas?
Deleted member 8987
And, if it isn't rotten all to pieces, you can usually fix the brass floats.
Unsolder the bung, drain it, resolder the bung, boil a pan of water, take it off the burner so it's hot but not bubbling, stick the float in and hold it down with something like a piece of wire wrapped around it. See where it leaks, mark it, let it cool, solder the hole and re-test (do NOT solder hot as when the air cools it can collapse).
Fized a lot of old Ford floats that way.
M
mallard
Thanks Scott for the link to MAC'S They have it for $4.95.
TOC my float is plastic so it can't be repaired but thank you.
DNK
You know something funny. I just replaced my sender and I used the stock style even though I am a BIG proponent of the Ford one.
Goes to show ya
HerronScott
Keith,
Sure thing. Note that shipping is $7.00 which is why I said it's $12.00 shipped (OK, $11.95). :smile:
Scott
dklawson
TOC, I have never seen a plastic float attacked by gasoline (new or old). I believe the floats are either polyethylene or polypropylene which are not affected by gas or alcohol.
Mallard, you can repair the plastic floats if you want to. As with the brass floats, you need to get all the gasoline out and you need to locate the source of the leak. You can then use a hot soldering iron to melt/flow the plastic together to close the hole and seal the float. It isn't pretty but it works.
There is one caveat about the Ford brass floats. The Smiths float arm often has a small burr on the cut end of the wire loop that holds the float. The Ford float can be punctured by this burr so be sure to take a file to the end of the Smiths float arm loop and remove any/all sharp edges.
M
mallard
Doug thanks for mentioning the burr on the end of the arm, I had not noticed it. That's where the leak was, at the end of the arm.
FlyingCat Spitfire Fuel Sender Unit Triumph 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
T Fuel Gauge & Sender Unit Austin Healey 5
I Fuel sender unit testing Triumph 2
Jeepster New fuel sender unit Austin Healey 9
J Busted Fuel Tank Sender Unit Screws Austin Healey 7
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
JPSmit Fuel tank sender - how does it work? Spridgets 4
Healey Nut Fuel Sender Austin Healey 3
J Fuel sender, fuel gauge 100 4 Austin Healey 6
sim fuel tank sender reading full all the time Spridgets 9
R Fuel sender internal wire Austin Healey 13
H TR2/3/3A Fuel sender or gauge? Triumph 8
L Fuel Tank sender 100/6 Austin Healey 8
S fuel sender Austin Healey 7
rjc157 Fuel tank sender Austin Healey 13
S Hot tip: seal for fuel tank sender Austin Healey 9
T TR2/3/3A fuel sender Triumph 12
J Orientation of sender in fuel tank Spridgets 2
G MGB Fuel sender '71 MGB MG 9
martx-5 TR2/3/3A TR3 Fuel Sender From Moss Triumph 8
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
pjsmetana Fuel Level Sender needed... Triumph 5
T How best to test a fuel sender off the car? Triumph 10
M Fuel Tank Sender? Triumph 2
Morris Fuel tank sender Spridgets 3
newmexTR3 fuel gauge/sender wiring Triumph 7
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
NutmegCT TR2/3/3A fuel gauge / sender TR3A Triumph 25
Randy Harris Fuel sender gasket - replace w/full Tank? Austin Healey 8
healeynut Ebay Fuel Tank Sender Austin Healey 5
jhorton3 Fuel Gauge Sender Spridgets 4
G TR6 Fuel sender resistance for TR6 Triumph 1
A Fuel tank sender - direction to install? Austin Healey 3
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
L Fuel sender specs... inaccurate gauge?? Spridgets 4
B Fuel Tank Sender Austin Healey 7
TypeRboy Fuel guage sender for Elans Lotus 0
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
