fuel pressure question
healeyboz
Would having different size lines in the system cause a problem with richness?
I have 5/16 line from the tank to the pump to a gauge and then step down to a 1/4 line to fit the su.
I am trying to locate a good regulator to put in line before the the carbs but it looks like I am going to have to step down to 1/4 after the regulator. Will this cause a problem?
I am thinking about what it is like with a smaller nozzle on a garden hose.
Thoughts?
bgbassplyr
IMO, Pressure should be the same anywhere after the pump. Size will only affect amount of fluid through the pipe, slower through the larger, faster through the smaller.
Sarastro
Yes that's right--won't affect the pressure. Flow rates are so low in these cars that anything related to them doesn't really matter. Make sure the pressure out of the fuel pump is OK--more than about 3 PSI could be a problem. I had all kinds of problems with float valves not shutting off until I installed a regulator and got it down to 2 PSI.
JPSmit
I'm rereading your post and while I know nothing - and I mean nothing about carbs, it strikes me that pressure might be an overflow/ flooding issue but that richness is more about finesse than flow. Assuming your flow needles are shutting off correctly and the floats are correctly set, I'd be looking further down the line.
Choke? Is it on/ shutting off properly?
vacuum - any leaks? / is air getting in anywhere - spray WD40 around manifolds joints etc and listen for sound change
Needle Adjustment?
Piston/ Piston oil?
might be more helpful
healeyboz
healeyboz
Carbon loading up in the exhaust and fuel in oil. The carbs have been rebuilt by Hap. I am pretty sure it is a fuel pressure issue--just trying to figure out how to fix it for good. I had a cheapo regulator on it and it seemed to help with the fuel in the oil thing. But I would get a horrible vapor lock. Took the regulator out and she ran again. :frown:
Barry sounds like yo are way too rich, I build alot of carbs, I know we talked Saturday, forgive me for not remembering about what, I recovering form a nasty stomach virus, and a little drugged up right now. At first we used the #3 needle with the jet at .070" down the bridge, and if I remember correctly, then switched you back to thew AN needle which is stock for the 1275. Both these needle and jet settings are pretty basic and seem to have worked many times with outher cars/customer/engines, not to say your car doesn't want something different, but if you're now running the AN needle with the jet about .070" down, that is the factory setting, if at that point you are still too rich, my thought would be that the timing is retarded which for sure would cause a rich condition, where is your timing set at, at idle and at 3000 rpms?
mrsprite fuel pressure question Spridgets 6
H Fuel pressure regulator question MG 2
BobHaskell SU Fuel Pump Pressure Austin Healey 1
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
aero3113 Fuel pressure Austin Healey 36
B Fuel Pressure Regulator Spridgets 5
KVH General TR Fuel Pump Pressure Triumph 16
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
M TR4/4A Fuel Pressure Regulator Installation. Triumph 3
N Fuel pressure regulator? Spridgets 10
A 100/4 Fuel pressure advice needed Austin Healey 1
bthompson What fuel pressure does a Weber DGV like? Spridgets 2
M How Do I check Fuel Pressure at Injector Rail 99 XJ8? Jaguar 5
S Fuel pressure Regulator is it really needed? Triumph 9
Henson80MGB Newbie w/ low fuel pressure issue MG 11
TR4 TR4/4A TR4 Fuel Pressure Triumph 20
T Fuel pressure regulator settings???? MG 7
T Recommended fuel pressure Spridgets 32
M 1987 XJ-6 Fuel Pressure Jaguar 9
P T-Series MGTD Fuel Pump Pressure MG 2
R correct fuel pressure Austin Healey 4
6 What Fuel Pressure? Spridgets 7
Bob Claffie Too much fuel pressure Austin Healey 9
Morris Midget EFI fuel pressure problem Spridgets 10
P fuel pressure problem MG 2
T Fuel pressure regulators Spridgets 25
kennypinkerton Fuel pressure test gauge? Alfa Spider... Other Cars 2
G fuel pressure Spridgets 4
T fuel pressure, roll bar Spridgets 15
P ideal fuel pressure for webber or dellorto carbs Triumph 11
Hegg Excessive Fuel Pressure - how do I stop the leak? Triumph 8
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
