Guys--gas everywhere from overflowing float bowls. I even bought new floats, needles and seats, and now I'm still rich and leaking again from both bowls. BUT, here are a few more new facts in case you have more thoughts or advice:
Both bowls appear to be leaking from the lids, right at the gasket. I've got new gaskets I can put in, but I've never seen those leak before. I pulled the lids, and the fuel is too high, even with the floats correctly set. In fact, the Moss Video says it's not all that precise. So, I tried one more adjustment to the float level, and it made no difference.
I then pulled the hose off the rear carb and there was so much pressure built up that gas shot onto the valve cover like a water pistol. Is that normal? It was a good squirt of three ounces or so.
I guess what puzzles me is that if the pressure is too great, wouldn't the gas just run out the overflow hole and not cause a leak at the lid? The problem can't be just my gaskets. Would it be a correct assumption that excessive fuel pressure is allowing enough gas into the bowl to cause both a rich mixture and a level just high enough to escape those gaskets?
I put a new fuel pump on four months ago. I've had this rich problem the whole time. The pump was the last of a run that had "defective" threading at both input and output. Nothing in the spec sheet mentioned any other defect.
So, my question: Is all this now sounding more like a fuel pressure issue?
PS Hey, Geo, thanks for the offer as always. You're too good to me. I may call you if I decide I don't need to own one.
