Front brake pads that dont squeak
bugedd
I have tried Moss brake pads with the foam backing that is supposed to get rid of noise, then I tried Beck Arnley pads (I think) with anti squeal goo on the back, and those are worse. Both pads had the edges chamfered. Is there a pad out there that wont announce to the world that I am braking?
jlaird
I got a set of drum brakes you might like, but then might not.
Mine were pretty squeaky until I heated them up a few times. Now the only occasionally squeak.
Try to bed them in again with 4-5 hard stops from say 50 mph. Then let them cool before using them again.
bugedd
bugedd
Does EBC or anyone make a performance pad, perhaps less squeaking with a softer compound?
bugedd
bugedd
Perfect! Now I know what I am getting for the old girl next paycheck
jsfbond
If you can find locally, look for the VGX brand of pads and rotors. They are made in America, and Canada. They have no intentions of going to China...ever! The rotors are coated with a compound to help mate pad, and rotor for optimum performance and long life. Thier ceramic pads have a silver colored base, and will not turn the front wheels/rims black.
TimK Uneven wear on Healey front disk brake pads Austin Healey 2
S Front Brake pads for 1966 Morgan + 4 Other British Cars 4
Bret Front Brake pads MG 8
W Weathered the front brake pads. *DELETED* Triumph 2
G Front Shock Replacement and Early BJ-7 Brake Pads Austin Healey 5
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
bighealeysource Front Brake Adjusters Austin Healey 0
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K TR2/3/3A Spacers to centre the the front brake rotor? Triumph 11
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
I Bug eye front disc brake conversion. Spridgets 5
bighealeysource Question on 100M front brake cylinder Austin Healey 4
M TR6 Front Brake Caliper Bracket Part Identification Triumph 0
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
John Turney TR6 Brake Line to Front Calipers Triumph 4
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
I Wanted Sprite front brake parts Spridgets Classified 1
K TR2/3/3A Front Brake Caliper Shims Triumph 3
T Assistance with Front Brake Lines Spridgets 3
doc50 Met front brake pistons Other British Cars 4
A TR2/3/3A 1960 TR3A front brake dust covers Triumph 5
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
AngliaGT Front Brake Dilemma - '74 cb Midget Spridgets 4
R TR2/3/3A Front Brake Conversion Triumph 5
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
G Rover P3 Brake Lining - Front Rover / Land Rover 2
K TR2/3/3A Front disc brake squeal.... Triumph 4
L Front Brake 100/6 Austin Healey 1
R Help with BJ7 front brake line routing Austin Healey 6
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
A TR6 '73 tr6 passenger front brake dragging Triumph 2
F Front brake hose BJ8 Austin Healey 4
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
F front brake hose 67 BJ8 Austin Healey 4
M Front steel brake lines Spridgets 9
certifiedcarnut 948 front brake shoes warning Spridgets 5
certifiedcarnut pipe between front brake wheel cylinders on 948 midget [drum brakes] Spridgets 4
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
R BJ7 Front Brake disc hitting Austin Healey 12
P Bugeye front drum brake picture Spridgets 7
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
bigjones Front brake job - any advice? Spridgets 94
RJS TR4/4A Replacing front brake hoses Triumph 10
